LJ towing with 35's - JeepForum.com
post #1 of 5 Old 09-27-2011, 07:44 PM Thread Starter
Md_06Unltd
LJ towing with 35's
I just replaced my 06 LJ with an 06 LJ Rubi.
I towed my 3500lb travel trailer with the LJ running 32" AT's and it towed fine.
For the LJ Rubi, I was considering 35" KM2's or XTerrains, but was wondering if the larger tire size would put too much stress on the rear axle to tow at the 3500lb capacity. (Also planning to add the OME lift w/ 1"BL)
Any LJ owners running 33's or 35's care to chime in?
01 XJ Sport
06 LJ Unlimited Rubicon
08 XK Commander
66 M416
Md_06Unltd is offline
post #2 of 5 Old 10-01-2011, 11:18 AM
olebluejeep
1993 XJ Cherokee
My father has an LJ Rubi with 35's and it has towed 3 800cc fourwheeler and about 200 lbs of tools and tool boxes and it towed just fine. Just the stopping part that was kind of tricky. Hope this helps some.
Stock Jeeper
olebluejeep is offline
post #3 of 5 Old 10-08-2011, 01:01 PM
Jtrux
You need to give yourself plenty of room to stop. Other than that it should be fine.
Jtrux is offline
post #4 of 5 Old 10-10-2011, 08:00 AM
unlblkrubi
Put a brake controller in it.
Black 13 JKUR 10th Annivsary
White 13 JKUR
___________________________________________
unlblkrubi is offline
post #5 of 5 Old 10-13-2011, 07:22 PM Thread Starter
Md_06Unltd
Thanks for the input, I had a prodigy brake controller on the old LJ, grabbed that when I was stripping parts off it at the body shop, and I always leave plenty of braking distance too.
I also use a Reese weight distribution hitch (which I highly recommend).
I'm sure I'll be fine, though I've decided to stick with 33's.
01 XJ Sport
08 XK Commander
66 M416
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 07:29 PM
35's in Jersey roadrunner2348 General Discussion 28 08-03-2007 10:15 AM
just got my 35's TAMUJeep General Discussion 2 10-20-2006 04:43 PM
0-60mph 8seconds... 35's 6in lift? wtf TXjeepTJ General Discussion 42 08-15-2006 02:54 AM
Is there any vehicles with stock 35's? river rat General Discussion 16 08-02-2005 09:20 PM
