Lightening an M101A1 or A2 - JeepForum.com
post #1 of 24 Old 10-22-2008, 03:29 PM Thread Starter
tjsahara1979
Has anybody done this? IE, cutting out the floor and putting in wood, switched out the axle, ect.
Originally Posted by Dave Barry
There is a very fine line between "hobby" and "mental illness"
'01 TJ Sahara. 3" BDS lift, 1" PA BL, 33x12.50x15 Nokian Vatiiva M/Ts, Durango steering box, soft 8s, RE steering stabilizer, and one LOUD effin' train horn :)
Green Jeep Club Member #183
tjsahara1979 is offline
post #2 of 24 Old 10-28-2008, 03:12 PM
RKBA
Do you have one already?
I won the auction for an A2 model; just waiting on the paperwork to clear so I can pick it up. My intent is to try and get it to a more manageable weight (and height).
As near as I can figure, the chassis makes up for about 800 of the 1200 lbs that it weighs. Of that, a good percentage has got to come from the wheels, tires, axle, hubs, drums, and brakes. The frame itself isn't overly massive; I would say it compares more favorably to the M416 than the M105 trailers.
The current rough plan is this:
A frame 2" ball coupler in place of surge brake lunette coupler
standard tongue jack instead of landing leg
3500 LB five lug electric brake standard trailer axle (spring under conversion)
remove a leaf or two from the springs
15" aluminum wheels
radial tires
Once I get started on the project, I will try to keep good notes on my progress - hoping to shed at least 400 lbs.
2002 TJ SE
2006 LJ
2007 Rockwood Freedom 2280
RKBA is offline
post #3 of 24 Old 10-28-2008, 03:30 PM Thread Starter
tjsahara1979
My basic plan was the same. I haven't gotten one yet but there are a ton of them around here. Keep us updated!
post #4 of 24 Old 07-28-2009, 04:48 AM
FALJEEP
US M101a1 trailer mods
I picked up two M101a1 trailers back in Febuary. I have the side rails and bows waiting a new paint job. Since then, I have removed the stock axle due to commonality of parts. Trying to keep everything simple, I purchased a 3500# Dexter axle and 5x4.5 hubs with electric brakes and Pro Comp Steel wheels to match the Jeep. Removing the axle was a little time consuming, but not too hard to do. I jacked up the rear of the trailer and removed the axle u bolts( had to cut off two of them due to corrosion) then with a little finess, rolled out the old and rolled in the new. Iam debating on weather or not to install LED tail lights as I currently am using the MIL Spec lights. I next bead blasted the outside paint just enough to rough up the surface to paint, and am currently waiting for mother nature to cooperate to shoot with a khaki paint scheme. Another mod waiting for parts is to install aircraft seat tracks to facilitate tie downs more uniformly.
A.I.O. Adapt, Improvise and Overcome
FALJEEP is offline
post #5 of 24 Old 07-28-2009, 08:35 AM Thread Starter
tjsahara1979
Do you think its light enough to tow with the TJ? Have any pics of it?
Thanks!
post #6 of 24 Old 07-29-2009, 05:13 AM
FALJEEP
Are you going to be towing with a short wheelbase TJ? If you are, things might get a little squirlly on you. I didn't have any problems towing my trailer, or trailers when I had them on top of one another. Max towing weight for a LWB is 3500#. I haven't been able to figure out how to upload pics, so if anyone wants to jump in and walk me thru it I would appreciate it.
FALJEEP is offline
post #7 of 24 Old 07-29-2009, 01:19 PM Thread Starter
tjsahara1979
Yeah mines a SWB
To show pics, upload them to a hosting site (photobucket, flickr, etc) and post them here. You have to be a paid member for them to show up so if I quote you, they'll show up
post #8 of 24 Old 07-29-2009, 04:02 PM
Indy
Indy's Avatar
You don't have to be a paid member, that's just the quickest way. Once you hit 50 tech posts, you can post pics.
Indy is offline
post #9 of 24 Old 10-24-2009, 01:34 AM
SplitPoly
2003 WJ
Any forward progress on this project or pictures of the current status? I'm feeling the bug to get one of the M101's. How much do you have into parts/hubs/axles, etc... Would it be cheaper to just go with a lighter trailer from TSC or Northern Tool?
Post pics if you can.
Thanks,
- Rick
SplitPoly is offline
post #10 of 24 Old 10-24-2009, 01:37 AM
SplitPoly
2003 WJ
Also, what is the difference between the A1 and A2?
post #11 of 24 Old 10-24-2009, 11:09 PM
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
What's the box dimensions on one of these? I've seen them for cheap and I'm wondering if I could make my TJ fit in one. I'm not so much worried about the weight of the trailer as I'd be pulling it with a 3/4 ton Dodge diesel.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #12 of 24 Old 12-08-2009, 12:26 AM
pohlease
M101A1 is the standard trailer
M101A2 has surge brakes.
pohlease is offline
post #13 of 24 Old 12-08-2009, 12:30 AM
pohlease
American m101s are 8 feet long and slight narrower than a truck bed. I can't remember what the measurement was. Will fit an ATV with some room to spare I think.
pohlease is offline
post #14 of 24 Old 12-30-2009, 10:42 AM
trailhead2004
1980 CJ7
The bed is approx 6 feet wide give or take a little but it's 4 feet + between the wheel wells.
This is a big trailer. It's unladen weight is 1350 lbs for an A1, don't know about an A2 but it has to be more with the surge brake assembly.
I just got one the other day and towed it home 300+ miles with a 6 cyl CJ7. It towed ok in the respect that it wasn't especially squirlly, but it pretty much maxed out the 258 for towing capacity. Granted my motor has 140k miles and is stock with the exception of the Howell TBI and headers, but I wouldn't want to tow it normally with anything less than about 250 horsepower. I was severely limited in speed on steeper hills coming home and there is no way I would want to go downhill with that trailer on the back of my rig. It's just too much weight.
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
post #15 of 24 Old 04-12-2010, 05:19 PM
RKBA
Bringing this back from the dead.
I got my M101A2 down to 1000 lbs, the tongue is 100 lbs. and it's four inches lower due to a spring under conversion.
Here's what I did:
Removed surge actuator/lunette - replaced with regular old A frame ball coupler
Swapped adjustable front landing leg for standard trailer tongue jack
The rear cross member was badly damaged by Private Snuffy so I simply cut it out
Replaced military axle w/5200 lb electric brake standard trailer axle - it has 12x2 8 lug drums and EZ lube spindles
Added small electric brake breakaway battery
No shocks
I think you could get down about another hundred lbs by using a 3500 lb axle with 10" brakes and lighter 15" wheels/tires. My eight lug steelies with LT235/85R16 tires tip in at almost 80 lbs each.
2002 TJ SE
2006 LJ
RKBA is offline
