Originally Posted by ajmorell
A ZJ with the 4.0 is rated to tow 5000lbs max
That being the case, you'll be limited to 5,000 lbs by the ZJ, regardless of the hitch ratings.
Depending on what you're going to tow, you may still want a WD hitch. A light-weight trailer shouldn't be an issue, but if you're close to 5,000 lbs, or over 500 lbs of tongue weight, then a WD hitch would be useful.
What do you plan to tow?
