01-05-2012, 08:22 PM
#1
How much would you offer?
75 cj5-304, 3.5" lift, T181b, D20, D30/D44, 3.73 owned sinced 1996 currently tore down to the frame, check that, tubs on lets start wiring....
83 cj7-258, 4" lift,T5, D300, D30/AMC20 Single Axle conversion, 4.56 owned since 2009...daily player.
01-05-2012, 08:23 PM
#2
Shiver me Timbers!!!
Originally Posted by mstrnater
They are hard to find and dont go cheap. If. They are truly originals the expect to pay about $1500 for a decent one. Much higher for an original nice one.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MYj Build
01-05-2012, 08:33 PM
#3
I've been seeing them on CL for a year or so... Must be the real deal and he knows what he has...
Any advantages of one over the others...
01-08-2012, 12:00 PM
#4
Really just depends on what you are looking for. The Bantams are the earliest from what I understand. The 416 came later and can be found easier. If i could pick one up for like $500 to pull behind my Jeep I would do it. $1500? Not so much, but I dint really need one so…
MYj Build
01-11-2012, 02:47 PM
#5
if you are planning on modifying and using the trailer off road, imho go with the m416, they are all fairly comparable in performance, but the older WWII have more historical value, i know several reinactors that really enjoy restoring them, the m416 are much more common and of less historical value, for reference i paid $400 dollars here in Florida for an m416 in really good shape and $150 for a rust bucket
01-15-2012, 09:33 PM
#6
Good info here. Only thing I would interject on is pricing. Up in this region things like these are harder to find and generally aren't terribly rust prone so they command higher prices. That and a lot of retired military live in the region so there is usually more demand than supply, USUALLY.
MYj Build
01-21-2012, 07:45 PM
#7
I am sure that is true, prices will definitely fluctuate depending on region and availability
