11-02-2011, 09:06 PM
#1
Junior Member
How long does the trailer need to be to tow 2 TJs?
If we want to take a 2006 TJ and a 2005 LJ (Unlimited TJ 2-door), how long does the trailer have to be? I will be looking to rent a goose neck trailer to pull behind a 2011 Ford Super Duty 250 Diesel.
God Bless Texas
11-02-2011, 09:09 PM
#2
I thought the F250 only had a 12,000 lb tow capacity? i would think with a gooseneck and 2 well built jeeps you're going to be pretty close.
99 TJ, NV3550 swap, D300, 4:1, 1 tons, 40's, full hydro, 14" coilovers, etc
2007 2 door, RK coilovers, built rubi 44's, 5.38's, etc
11-02-2011, 09:26 PM
#3
A few more details on the Jeeps would help. Stock, built with tire carriers, etc. would give us an idea on weight. The said, Mine weighs around 4.5k, LJ. 2 of those would be 9k. That leaves you 3k for trailer weight assuming 12k tow rating. I would think you could get away with a 28'-30' long trailer. Yank any spares off and throw underneath/inside to shorten the overall length of the Jeeps.
TT
At that point where it's too much to list!
11-02-2011, 09:44 PM
#5
Weight won't be a concern with that truck unless you're in the mountains but in south Texas or anywhere in Texas you will be fine. I'd say something in the 30' range would be good. There would be plenty of room to manuever around when strapping them down. Oh and that trailer won't weigh 3k, probably more like 6k. My 20' bumper pull car hauler weighs 3100. 6" C channel, 5200lb axles, brakes on both axles.
Woogity boogity
11-02-2011, 10:04 PM
#6
I agree with Jtrux on the trailer weight. I was probably a little light. My guess would be in the 4k-5k range.
TT
11-02-2011, 11:15 PM
#7
You won't even know that you're towing 12k pounds with that truck.
11-03-2011, 04:50 AM
#8
32' deck works great, with some space to breath. A 28' will work with two TJ's, no spares, and stubby bumpers.
However, if you get a good trailer, it's going to approach 10k lb by itself.
2003 TJ Rubicon
11-03-2011, 07:13 AM
#9
according to the ford dealer, the only difference between the F250 and F350 is 1 leaf spring. So i agree. (my buddy just bought an F250 and considered a SRW F350)
HOWEVER, johnny law knows the difference if you're over weight. That's why i was asking.
Now that i think about it though i think bumper pull was 12,000. I bet a gooseneck/5th wheel is rated a little higher.
11-03-2011, 07:28 AM
#10
Junior Member
Originally Posted by Unlimited04
I believe that would be perfect for the job.
God Bless Texas
11-03-2011, 08:00 AM
#11
That doesn't seem right. The F150 EcoBoost has a tow rating just north of 11k, there's no way the 250 with a powerstroke is just a few hundred lb more.
Andy
'98 Jeep ZJ "Pearl"
11-03-2011, 08:12 AM
#12
Here's Ford on the subject:
http://www.ford.com/trucks/superduty/specifications/towing/
Capacity looks to be around 16k, depending on configuration.
11-03-2011, 09:02 AM
#13
you will need a 20' trailer to get 2 TJs on, you may have to load them nose to nose if they have big aftermarket tire carriers, but a 20' will get both with a little overhang, no matter what you pull it with
001111001000110000100111101101101110110000
100101011100000010110011000111001111101101
110001100110100001010011010010001100010100
111001100001110111000010001001001101100111
0000011111011110100111000000101001000001
11-03-2011, 09:41 AM
#14
Yeah, 14k for a bumper tow, 16k for a 5th wheel/gooseneck is what I'm seeing
Andy
'98 Jeep ZJ "Pearl"
11-03-2011, 02:04 PM
#15
Junior Member
From front of the bumper to the back bumper (with the spare removed), my LJ is 14' 8". I could easily let part of the front of my jeep hang out of the back, since there is 32" between the footprint of the front tire to the front edge of the front bumper. I guess letting 20-24 inches hang over would work. The other TJ (regular length) is about 13' 2" total length. I guess you need a foot or so between them. To me it looks like it would take a trailer that was at least 27 feet to make it work, and 30 feet would be ideal.
176" my LJ
156" the other TJ
12" space between the Jeeps
344" total (28' 8")
-20" overhang
324" (27 feet)
God Bless Texas
