How do you attach the Jeep to the Trailer? - JeepForum.com
post #1 of 8 Old 09-24-2006, 02:54 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Right now I attach the strap around the diff pumpkins with ratchet straps. How do you attach your jeep to the trailer. I've heard good and bad things about attaching the jeep to the bumpers vs the axles.
Do you use chain or straps? I've been thinking about going with chain on the rear but haven't decided.
What do you all think?
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 8 Old 09-24-2006, 04:30 PM
z71offroader
z71offroader's Avatar
i like using straps compared to chains. but straps can stretch so u have to check them everytime u pull over. but i think chains are more dangerous. but using a chain just to loop it around an axle, not tight can be helpful incase a strap comes loose.
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more.
07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come!
(Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more.
z71offroader is offline
post #3 of 8 Old 09-24-2006, 04:42 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I have a set like this. Two adjustable length loops and two ratchets. The loops are adjusted to go from front shackle to the trailer. The two ratchets are around the rear axle and to the trailer. This setup gives two independent connections at each end.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 8 Old 09-24-2006, 07:27 PM Thread Starter
JeepRocks86
I was thinking about doing a set of those. The thing i'm worried about with doing those is with the rear brake lines. I don't want to pinch them with the straps. I was thinking about using a chain in the rear due to the way my Nth Drive shaft skid rubbs the srap wrong and then a strap on the rear.
Where did you get your individual strap kit?
Do you all attach it to the body or to the axle?
I'm just wondering if I could figure out a better way to strap it down.
For Sale:
post #5 of 8 Old 09-24-2006, 08:00 PM
JeeperDon
JeeperDon's Avatar
You will have to relocate the brake lines a bit, or replace with longer ones not in harms way, no clean way around that. I got my straps at a trailer place when I got the trailer years ago. I found the pic through Google.
Web Admin for
post #6 of 8 Old 09-25-2006, 01:33 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
mine is close to JeeperDon's...but I use ratchet straps and axle wraps...instead of the fancy one-piece deals...
because I needed them the next day, and it's what I could find locally...
the axle straps were $9.99/each from Northern Tool:
http://www.northerntool.com/webapp/w...70_28659_28659
and I think my straps came from Home Depot...but they're similar to these:
http://www.northerntool.com/webapp/w...70_12820_12820
I go from the front axle straight ahead on both sides, and around then cross the straps on the back around each side of the pumpkin...
four independent connections, all tied to the axles...
front looks something like this:
rear looks like this:
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #7 of 8 Old 09-25-2006, 08:26 PM Thread Starter
JeepRocks86
Yea I was looking in the Northern Catalog today and saw those straps. I have the same as the second link that I use front and rear. I think mine were from pep boys as a christmas present last year.
For Sale:
post #8 of 8 Old 09-26-2006, 06:17 PM
JTB51B
I haul a LOT of cars and we till tie down with the wheels if possible. We have straps that are 1.5" with d loops on each end, run those through the holes in the wheels and hook to a binder strap attached to the trailer. One thing that will help is to cross your straps, right rear goes to left rear of trailer and so on. By tying down with the wheels you eliminate the suspension even tho the axle offers the same thing there are no brake lines to contend with at the wheels. This only works if you have wheels with no sharp areas to cut the straps, in that case wrap up the axle.
Jason
DD-- 2005 Dodge Ram 2500 Cummins TD Quad Cab 4x4 6 speed
Toys:
1998 Sport Auto trans, 3.73 gears, D30/lockright D44/Detroit, 33" Mud tires, FT LCA's JKS Adj. Trac bar FT 4" coils, RE GEN II Disco's--1 1/4 JKS BL, 1" MML XD9000i up front, HD bumpers with extraction points.-Done.
1973 cz 250 MX Not much suspension, but 36 BHP at 6k rpms!
2006 Rhino SE, 27" Mud lites and a cupholder.
JTB51B is offline
Travel travel trailer good base for a Jeep Trailer YJames90 Trailers & Towing 7 04-15-2009 01:28 PM
A Trailer for My Jeep ShowmetheSign General Discussion 2 07-18-2007 02:49 PM
How to attach the tow brackets? nonnaca Trailers & Towing 9 04-02-2007 08:01 AM
What to attach winch to if on a barren landscape? Achped General Discussion 20 07-03-2006 03:47 AM
When can I attach pics? The Tenn Man General Discussion 13 10-14-2004 09:30 AM
