How to best ground single wire clearance lights? - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > How to best ground single wire clearance lights?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 10-31-2011, 09:30 PM   #1
tw_jeep
Redoing some of the clearance lights on our horse trailer. They are single-wire grounded through the mounts. The OEM lights were essentially riveted to the trailer and grounded through them.
I have to replace some of them and was going to use SS hardware. Would a small screw or bolt/nut combo be best? Just want a good ground... and something that wont vibrate loose.
The new lights did not come with mount hardware. They are these:
http://http://www.pmlights.com/products.cfm?cId=2&fId=1&pId=2749
Or am I over-thinking this?
Thanks
Tom
2000 TJ Sport/auto/D44/X8000i & Tomken mount/jeeperman rear bumper and rails/Skidrow steering skid/RE 3.5SF/33x10.5x15ATKOs/JB Conversions SYE/CV shaft/BESTOP tire carrier/AtoZ front bumper/Front Aussie Locker/some aesthetic stuff/
tw_jeep is offline   Reply With Quote Quick reply to this message
Unread 11-01-2011, 05:22 PM   #2
USMCredneck
1979 CJ5
A regular nut and bolt with a lock washer should be sufficient. Clean the backside of the mounting surface down to bare metal and you should be good to go.
79 CJ5. 258, T-18A, D20. 33s
08 Dodge Ram 3500 DRW DD/tow rig
USMCredneck is offline   Reply With Quote Quick reply to this message
Unread 11-01-2011, 09:02 PM   #3
tw_jeep
Nice and simple - thanks!
