Hitch Heigth - JeepForum.com
post #1 of 3 Old 11-19-2008, 06:23 PM Thread Starter
Silverton34
Hitch Heigth
I am buying a trailer to haul my Jeep tomorrow and need to figure out how much drop I need for a ball mount. The trailer sits level with the top of the coupler 18 inches off the ground. The receiver on my truck is 23 inches from the ground to the center of the two inch receiver. If I buy a six inch drop ball mount where is it measured from? Top of the two inch shank to the top of the flat part where the ball bolt through? I really don't know and want this thing to tow REALLY level. Any thoughts on how a drop ball mount is measured?
Silverton34 is offline
post #2 of 3 Old 11-19-2008, 11:16 PM
MTheMonkeyBean
etrailer quick guide should atleast start to answer your question.
You want to see how much your tow rig will sag with the proper tongue weight and minus that out of the calculated drop.
The way I did it: I bought a cheap adjustable ball mount from HF. Then loaded up the trailer with the jeep to find the position that gave me ~13% tongue weight and adjusted the ball mount untill the trailer was about level. Figured out what drop I needed and bought a proper ball mount.
MTheMonkeyBean is offline
post #3 of 3 Old 11-20-2008, 05:29 PM
wilson1010
You have to determine the amount your receiver is going down when you load the tongue weight on the tow vehicle. Here's an explanation of how to do it:
http://www.jeepforum.com/forum/showt...ue#post5950358
Then follow the measurement instructions here:
http://www.etrailer.com/faq_ballmount.aspx
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
What hitch should I put on my jeep? juggle9 Trailers & Towing 11 06-19-2007 02:49 PM
Hitch wiring how to? mahgnillig Trailers & Towing 4 03-09-2007 05:12 AM
Need Measurements for a tow hitch MarineMurdock Trailers & Towing 0 03-07-2007 06:55 AM
Putting Hitch on WJ jkraft24 Trailers & Towing 2 03-01-2007 07:12 AM
Need to buy a hitch ... XJ99 General Discussion 5 01-22-2002 09:36 AM
