Harbor freight trailer build - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Harbor freight trailer build
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineRCV Axles at CCORRough Country Lift Kits and Parts!
Unread 04-16-2015, 01:45 PM   #1
Wagex
Harbor freight offraod trailer build
figured id finally do a log as im starting to near completion with it finally. il be updating as i go along, heres some pix of the process so far. its been a pretty low budget build being pieced together over the last year or so.
made the tongue from 2" square tubing slid inside 2.5" square tubing one bolt goes into the hole to lock it in place, the other just puts pressure down on the inner tube to keep it from moving around or vibrating. did one of those on my hitch on the jeep as well made so much less hitch noise.
craigslist wheels and shoes, $10 per tire and $20 per wheel tires are still about 1/2 tread. they come out to 32.6 inches iirc after the metric conversion on 18" wheels. will be nice to not drag axle half the trail or have all my stuff get wet because the trailer was half under water, lol.
yaks loaded up could touch the back tires with the tongue lol
finally got the tires and wheels on with a new axle 5x4.5 lug pattern
these last few pictures are all from this week and last been getting alot of work done on it as my daughter (pictured) is finally old enough to take camping want to have it ready by then. have a campsite reserved for june 12-15.. so still some time left.
built the box from 2x12's, took 4 of them total cost of like $40 from lowes the 3/4 plywood i had left over from remodeling my bathroom last month lots of woodglue and angled wood screws to hold it together. after i lag bolted it to the frame it stiffened the poor frame up quite a bit.
no good pix to show plasti-dipped the frame black and the white is a barn / fence paint, hoping it holds up well.
16 gallon tank added from class a customs, i sealed all the wood before i painted it with left over floor sealer i used in my bathroom gives the exposed wood a nice shine.
used a dock cleat to wind the spare wire up on when the tongue is retracted
new latches installed, really stiffened it up though being made from 2x12's it was pretty sturdy to begin with.
sorry the text is short and sweet just whipped the thread together on my lunch break alot of info over a short thread lol. future posts will be more detailed as im starting to take more pictures as i work on it more.
Wagex is offline   Reply With Quote Quick reply to this message
Unread 04-16-2015, 08:13 PM   #2
smokeybear
Nice rebuild!
02 TJ Sahara 4.0 5 spd, 3.73, Dana 44 rear, 2" Rubicon Express BB w/ Bilstein mono shocks, Warn M8000, 33x12.50 General Grabber AT2.
formerly 92 YJ 4.0 5spd, 3.5" Black Diamond lift, 1 inch Daystar body lift. 1 inch motor mount lift, Warn M8000, 33x12.50 BFG ATs, Ford 8.8, 4.10
smokeybear is offline   Reply With Quote Quick reply to this message
Unread 04-16-2015, 08:40 PM   #3
Wagex
Originally Posted by smokeybear View Post
Nice rebuild!
thanks! more updates coming soon, water pump and some electronic goodies are on the way
since these forums done seem to have the strike through bbcode il just highlight completed items in green.
list of things to to
-wiring
-plumbing
-fenders(temp fenders on)
-propane tank mount
-stronger hinges on the tailgate, the ones on there are just some i had laying around not heavy enough, going to replace the poly straps holding it with some chain as well so it can be sat on
-kickstand / maybe a rear stabilizer
-maybe some slideout drawers for cooking stuff as the tailgate is likely where my camp stove will be.
-tongue storage
-spare tire carrier
-support to hold the lid open
-roof top tent (when i hit the lottery LOL)
-list never ends.
rear main seal this weekend on the heep thoough. not to mention the never ending rain all weekend we are supposed to be getting.
Unread 04-18-2015, 10:25 PM   #4
Wagex
some sketchy at best fenders, lol i took the originals and just bent them out to give them a little more coverage, atleast they will keep mud from caking the side of the trailer and keep rocks from being flug into the back window of the jeep
the shelf is for cooking stuff, pots, pans, food, ect. it has two holes drilled into the back side of it that slide over the pins seen in the next two images works good for its intended use only holds 20lbs or so max, and easily packs away against the wall of the trailer inside.
redid the poly straps with some 550lb chain and i can finally just plop down on the tailgate without having to worry about it ripping the straps.
also have soem d-rings to mount but not sure where i want them yet.
new rms no more oil leaks
Unread 04-23-2015, 05:47 PM   #5
Wagex
Got some goodies in the mail today
Unread 04-23-2015, 05:55 PM   #6
Wagex
2.9gpm @50psi demand pump ecco flo propane tankless hot water heater, came with shower head and regulator hose.
$5 ebay special led's to go in the trailer, might just use one they are alot brighter than i was expecting!
built my propane tank mount out of some 3/8 steel strap i had laying around, yeah a bit overkill, but hey it aint going no where. lol.
Got some goodies today sorry I'm on my phone will update more this weekend once I start hooking stuff up!
starting to rush now, have a men only trip planned for next weekend (may 1 2 3) want to have everything atleast functional not exactly pretty by then lol.
Unread 04-27-2015, 07:28 AM   #7
Wagex
heres the updates from this weekend
tank mount came out pretty good made it from some leftover strap i had from building my storm shelter.
plumbing mostly done, till i figure out how im going to do the fill / vent lines any ideas? was thinking one of those little gravity feed things like an RV has would probably work well.
all in all its packed up and ready to load up and head out friday after work. for our first trip just stop for ice and beer.. err food on the way home.
im one of those people who will forget stuff so i figured being packed now, i will remember something i forgot, hopefully 4 days is enough time to remember everything i need.
i really need to find some kind of small spice rack or traveling spice rack, plan on cooking some fresh fish we catch out there
Unread 04-27-2015, 08:42 PM   #8
smokeybear
Looking good!
Unread 05-01-2015, 08:35 AM   #9
Wagex
loaded up and ready to head to the river for the weekend, sitting at work now waiting for 1:00... lol.
Unread 05-04-2015, 06:29 AM   #10
Wagex
first trip out went excelent went and stayed 3 days 2 nights at a spot with a friend there. trailer performed excellently i did have one small water leak at the 3/4 to half inch barb fitting on the back of the spigot but fixed that when i got home.
two guys not being very sparing with the water including a shower each and washing dishes after every meal we still came home with at least 3 gallons left in the 16 gal. tank.
Unread 05-05-2015, 11:48 PM   #11
Irish-n-Zwack
Wonderful setup you built, there. My husband, especially, would love it. He really loves camping. To me, though, "camping" is best done in a motel room with running hot/cold water, a small fridge, and a microwave :-).
I'll show this to Z in the morning. He may want to try something similar, himself.
"In the end, only kindness matters."
Irish-n-Zwack is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 11:50 AM   #12
dooboy2112
Cool little trailer.
2000 Grand Cherokee Limited
2000 Wranger Sport SOLD
1979 Wagoneer SOLD
dooboy2112 is offline   Reply With Quote Quick reply to this message
