Harbor Freight Folding Trailer: Modification / Write-up / Review - Page 3 - JeepForum.com
post #31 of 86 Old 09-30-2008, 07:06 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Originally Posted by Golfer2000 View Post
Do you have any pictures of your old modified trailer?
Unfortunately no. If you look at the HF trailer, you can get an idea. I ran 3 8' lengths of 4x4 from front to rear (1 on each side and 1 down the middle). Bolted that to the frame and then ran 2x6s from left to right leaving about an inch space between the wood.
Make sure if you use this trailer you MUST get new 2000lbs hubs from Northern Tool. They cost about $40 for the pair. The hubs that come with the trailer are garbage and I have seen them break numerous times.
Also make sure you bolt the frame together so it cannot fold. It will take 4 bolts and the holes are already on the frame to do this.
This is the best I can do. I spaced the wood more on the pic to show you the 4x4 underneath.
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
post #32 of 86 Old 11-06-2008, 11:28 AM
Golfer2000
Thanks!!!!!!!!!!1
Golfer2000 is offline
post #33 of 86 Old 05-01-2010, 05:05 PM
rob-ert
what do they call those corner brackets
where did you get them
what brand
or any clue to help me find them
thanks
rob-ert is offline
post #34 of 86 Old 05-01-2010, 10:20 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Nice job - you took a trailer that is pretty darn good (my bro-in-law and I have one) and made it even stronger.
I have to say I'm very impressed with the HF cargo trailer - doesn't cost a whole lot, and it puts up with a heck of a lot of abuse. The HF steel sides are nice to have too.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #35 of 86 Old 07-24-2010, 07:22 PM
cpy911
Fantastic write up, and thanks for the detailed drawings. ]
What type of welder are you using? How much depth does a welder need to go to get good welds like you have done? I am going to buy a welder to follow your lead in building the exact trailer and wonder how powerful of a welder I need (wire feed).
Thanks!
cpy911
cpy911 is offline
post #36 of 86 Old 08-07-2010, 05:54 PM
mora2818
Corner Brackets
Thanks for the write-up. I am using some of your ideas to build a cheap rafting trailer. For those asking about the brackets, do a search for "Corner Stake Rack Connector Set" and you should find several places that sell them. I couldn't find any locally at the hardware stores so I had to order them online. Cheers
-Kevin
mora2818 is offline
post #37 of 86 Old 09-05-2010, 03:39 PM
fishinjeeper
Wow, I know this thread was written a long time ago. but this is a great write up. thanks
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #38 of 86 Old 11-28-2010, 08:40 PM
IslandTractor
I have the same trailer. I found the 2 inch caster wheels used to move the folded trailer to be poor. Switched them out with 3 inch castor wheels obtained from Harbor Freight and it works much better. Easier to push, smoother and works on rough surfaces/cracks/etc better. Simple wrench on/off swap.
IslandTractor is offline
post #39 of 86 Old 11-28-2010, 08:48 PM
hookedupinc
Noooo pics?????
"Aw, jis taws a D-sisty aNNa SEE-fortene in air, an-U kin hit da mudHO wit me and Bubby dis weakin."
http://www.jeepforum.com/forum/f12/project-jevy-984905/
hookedupinc is offline
post #40 of 86 Old 01-02-2011, 07:21 PM
Wlai
Oh no, what happened to the original poster's detailed pics? Any chance we can get them back?
Wlai is offline
post #41 of 86 Old 01-02-2011, 09:06 PM
FPKites
ZJjazzyJim
FPKites's Avatar
He hosted them somewhere else - we don't have any control over it.
You might try sending him a PM to see if he's around and can provide the pics.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #42 of 86 Old 01-04-2011, 01:29 AM
Wlai
dup
Wlai is offline
post #43 of 86 Old 01-04-2011, 01:32 AM
Wlai
...dup deleted...
Wlai is offline
post #44 of 86 Old 01-04-2011, 07:33 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Try again with your photo please. I'm having a hard time picturing which hole you're talking about.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #45 of 86 Old 01-04-2011, 08:26 PM
Wlai
Now with photos
dup
Wlai is offline
Harbor Freight hoosier724 General Discussion 8 04-29-2012 08:31 PM
Harbor Freight Trombino General Discussion 2 08-22-2008 03:52 PM
Harbor Freight Folding Trailer Mod: Bumper waterboarder Trailers & Towing 1 08-11-2008 08:36 PM
Harbor freight frumpy General Discussion 30 03-25-2008 09:27 PM
Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures RickyN29 General Discussion 0 02-20-2007 10:38 PM
