Flat towing YJ with Aussie in Front - JeepForum.com
post #1 of 5 Old 04-03-2012, 04:23 PM Thread Starter
jvhooser
I have a 1991 YJ with a Detroit locker in the rear and an Aussie in the front. The front has a cable that replaces the vacuum actuator for the axle.
I have seen several threads concerning flat towing with the Aussie in the front and the choices seem to be disconnecting the front shaft, or replacing a part in the transfer case to allow true neutral.
Will the cable actuator rather than the vacuum actuator make any difference when flat towing the Jeep?
Disconnecting the front driveshaft is no big deal, and tearing into the transfer case is over my head so that makes my choice easy if the cable-vs-vacuum actuator does not make any difference.
I should have done more research before buying the Jeep since I knew I would be flat towing behind an RV when I bought it. I had no idea at the time that a locker would matter, or that the YJ transfer case did not have true neutral.
I bought a great Jeep that I can't tow without taking it apart.
jvhooser is offline
post #2 of 5 Old 04-05-2012, 09:19 AM
Indy
Indy's Avatar
The cable and vacuum do the exact same thing. The passenger side axle is 2 pieces with a sliding collar. The actuator just slides the collar to connect the axle. Without that, no front wheel drive. If youre ok with the locker and vacuum then youre ok with the cable. Just make sure the cable has the axle disconnected before you tow.
I'm the only gay eskimo.
Indy is offline
post #3 of 5 Old 04-05-2012, 11:07 AM Thread Starter
jvhooser
Indy, Thanks for the response. It is my understanding that the cable serves the same purpose as the vacuum unit, but the vacuum unit only engages the front axle when the transfer case is put into 4wd.
However, I can use the cable to engage/disengage the front axle independant of the transfer case.
If the front axle is disengaged by means of the cable, the transfer case put into neutral, and the transmission put in gear is it safe to flat tow this Jeep with an Aussie Locker in the front?
Will disengaging the front axle with the cable serve the same effect as removing the drive shaft when towing. I want to make sure the front differential is not binding due to the locker when I am towing.
Thanks
jvhooser is offline
post #4 of 5 Old 04-07-2012, 03:56 PM
Indy
Indy's Avatar
The tcase should be letting the front dshaft just free-wheel when its not engaged. And with the passenger axle in 2 pieces there shouldn't be any way for it to bind either. As long as the axle is separated and the tcase isnt in 4wd it shoudnt be any different than flat towing with an open diff.
I've never flat towed a yj so I don't know the proper tcase/tranny settings needed to keep it alive. My advice, post this question over in the YJ section. Substantially more active than this section, you'll get good info.
If you're wondering, the vacuum mod is a really failure prone item. It leaks and doesn't flex when it gets old. Either can keep you from having 4wd when its cold and/or you really want the front axle to work. Like when you're elk hunting, its fing cold, and getting dark and you're stuck on an ice covered climbing trail to get back to camp and you have no idea why you can't get the front axle to work. Just a f'erinstance.
The cable is a good fix. Or you go cheap like me and just run a long screw through it so the axle is always connected and the tcase just controlls 2/4wd.
Indy is offline
post #5 of 5 Old 04-09-2012, 10:12 AM Thread Starter
jvhooser
Thanks Indy, that's what I was hoping. I hate to have to putt the front driveshaft everytime i get ready to tow the jeep. I will repost in the YJ section for sure.
jvhooser is offline
flat towing cj7 TankCJ7 Trailers & Towing 13 02-20-2012 12:56 PM
flat towing cj gladetop Trailers & Towing 1 02-16-2009 11:12 PM
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 07:29 PM
Flat Towing Thetrav5.9 Trailers & Towing 0 06-28-2007 09:41 PM
Flat towing my CJ with my LJ dirtbagofva Trailers & Towing 3 06-19-2007 04:17 AM
