Flat towing procedure! - JeepForum.com
post #1 of 7 Old 08-12-2012, 03:40 PM Thread Starter
PERRI 56Y
I asked this same question in 09' and I received too many different answers to flat tow my 01' TJ automatic to Wyoming.I appreciated all the help but I need someone with the same setup to walk me thru the steps.PLEASE.My Dad towed it to Wyoming every year but the steps to do it were lost with him.I own it now and I want to tow it this year.Where to turn the key,what to put the Tranny in and what to put the Transfer Case.Thanks!!!!!!!!!
PERRI 56Y is offline
post #2 of 7 Old 08-12-2012, 04:34 PM
99_TJ_Wyoming
key turned forward until steering unlocks, then back till it stops without pushing the button, this unlocks the steering, the transfer case in neutral, the transmission in 1st or park, thats it, your ready to go.
99_TJ_Wyoming is offline
post #3 of 7 Old 08-13-2012, 05:33 PM Thread Starter
PERRI 56Y
Thanks TJ Wyoming!!!!
post #4 of 7 Old 08-15-2012, 02:12 AM
MPond
Not to argue, but step 6 in the manual shown above just says "Shift manual transmission into gear...", it doesn't specify 1st gear.
If you have a manual, the general consensus is to shift into your highest gear (5th or 6th, depending on your transmission). For all intents and purposes it'll make no difference - any gear will prevent the transmission from rotating, forcing all of the movement to occur within the transfer case, which is what you want.
But should something go wrong and the transfer case become re-engaged, you'd rather be in 6th gear while towing at highway speeds, than 1st gear. Any resulting damage would be less severe. It's a very unlikely scenario, but since it makes no difference which gear you use, I always use 6th.
And I just returned from flat-towing my LJ for over 2500 miles.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #5 of 7 Old 08-15-2012, 03:19 AM
99_TJ_Wyoming
Very glad I could help, hope you have a safe and enjoyable trip
post #6 of 7 Old 08-17-2012, 08:28 PM Thread Starter
PERRI 56Y
Thank you again TJ Wyoming.Thank you MPond for your input,You guys were the only ones that steped up!!!!!!!!!!!!!!!!!!!!!I have a 4.0 with a automatic MPond.
post #7 of 7 Old 08-20-2012, 12:33 PM
MPond
You're welcome. If you have any other questions, feel free to PM me.
MPond is offline
flat towing cj7 TankCJ7 Trailers & Towing 13 02-20-2012 11:56 AM
Flat Towing a YJ Tompatt Trailers & Towing 3 05-25-2009 03:33 PM
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 06:29 PM
flat towing frumpy Trailers & Towing 17 03-22-2008 08:20 AM
Flat towing my CJ with my LJ dirtbagofva Trailers & Towing 3 06-19-2007 03:17 AM
