Flat Tow a TJ ?? Tow Bar ?? Brake Assist?? - Page 3 - JeepForum.com
post #31 of 42 Old 03-07-2010, 04:02 PM Thread Starter
Mike_Motorbike
This is the bracket I made.
Its 2x2x4" stainless steel.
That BIG hole is to get the socket through.
I cut one of these hooks .
To fit here.
This is them instald.
From ground up..
Side view... Added a nut as a shim for stability.
And Viola Tow Bar...
View of chain.
Here's the HF Lights.
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #32 of 42 Old 03-07-2010, 06:04 PM
wilson1010
Very nice design and work. And some great photos too.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #33 of 42 Old 03-16-2010, 08:31 PM
driftwood98
Guys thanks for info, I will be towing my TJ to the beach (300 miles) with our Volvo XC90 V8 AWD (towing capacity is 4500#) . I am wondering how much of a decrease in MPG you guys see. The drive from Atlanta to Hilton Head is basicaly flat, down hill about 1000ft there and up hill on the way back. I have already planned to drop my average speed from 78-79 to about 60. I typically get about 21 MPG hauling a**. Hoping for 14-15 so towing will be a wash, kinda like we drove the Jeep but had the comfort of the Volve. Am I being optomistic? BTW just towing the TJ to have it a the beach for cruising.
Thanks for any input. I will post pics of the rig once it is all worked out
driftwood98 is offline
post #34 of 42 Old 03-16-2010, 10:07 PM
chadsmeltzer
chadsmeltzer's Avatar
Towing my TJ with my friends V8HO WJ we usually go from 20 unloaded to about 12-14 towing my Jeep. That's the exact same stretch of highway (175 miles one way, traveled twice a week) averaging 65MPH.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #35 of 42 Old 03-17-2010, 08:06 AM
driftwood98
Thanks Chad, so it looks like the trip will cost about $45 extra in gas round trip ($45 / 550miles = $.08 a mile). That is in my opinion is a small price to pay to have the TJ availalable for cruising, trips to the grociery store and dragging the kids around. The trip will take a little longer maybe 45-55 minutes, I am not sure what my safe tow speed will be just yet (275 miles / 75 = 3:40 hauling A** - 275 miles / 60 = 4:35).
Thanks again Chad.
Any pointer besides leave plenty of stopping room?
How agressive where you in the testing portion of setting up your rig, something tells me to preform a "panic stop" from speed before I get the wife and kid in the truck. What do you think about practicing some stops and lane changes at speed?
post #36 of 42 Old 03-17-2010, 10:31 AM
chadsmeltzer
To be honest, the first time we hooked up was about 10 minutes before we went on a 400 mile trip, we were on a time crunch. My buddy got in his Jeep and I got in mine which was hooked up and we went down the road slowly at first to make sure everything was working right. Then we tried a hard stop and it seemed to do okay. Remember that your TJ is a lot of weight behind you. It won't take long to overheat your brakes. Also, while going around turns the TJ will want to push your back end out, sorta like jack knifing. It's usually not very noticeable, the only time it ever broke loose was on a slippery road making a sharp turn and accelerating.
Remember, it's nearly impossible to back up. Plan that into every time to stop.
post #37 of 42 Old 09-06-2010, 10:30 AM
wolfcreek
Just installed the Harbor Freight towbar on my TJ yesterday... mounted the brackets to the bottom of the bumper, piggybacking the torx bolt for my warn bumper for the inboard bolt and drilling a hole for the outboard bolt.
I've never flat towed a vehicle before... the HF manual says to lock the steering wheel in the straight ahead position - is this necessary and if so, how?
Or as others have suggested do you just leave the key in and the steering loose - is caster supposed to keep the front wheels straight?
wolfcreek is offline
post #38 of 42 Old 09-06-2010, 12:34 PM
Kris_Kris
Leave the steering unlocked. The jeep will track behind the tow vehicle. The T-case in nutral (test it / double check it) and put the trany in gear (preferably a forward gear) or park.
Kris_Kris is offline
post #39 of 42 Old 09-06-2010, 02:29 PM
wolfcreek
Thanks! Just took the rig out for a test drive and it seemed to work great. Front wheels turn as if by magic :-)
I cut apart the 2 safety chains that have a hook at each end and put the chain link end through the u-bolt on the tow bar. So now I have 4 hooks, two of which go into the hitch receiver and two into the holes in the side of the jeep's forward frame rails.
HF tow bar: $59.99
Magnetic tow lights: $9.99
Safety chains (2) 19.98
Total cost of set up: $89.96 plus tax
post #40 of 42 Old 09-06-2010, 05:02 PM
Kris_Kris
HF tow bar: $59.99
Im not sure what you are towing with but be carefull brakeing and turning at the same time. If your tow vehicle is light in the rear (empty pickup) or the roads are wet, it will push the back of your truck around.
post #41 of 42 Old 09-06-2010, 06:11 PM
wolfcreek
Good advice, and I will certainly approach it with caution - especially braking in turns, descending, etc. Don't plan to exceed 55mph.
My tow vehicle is a crew cab F-450 which weighs almost 9000 lbs empty and probably around 14k with the camper on it.
post #42 of 42 Old 06-09-2012, 08:02 PM
morr1
Been searching..but need help on the best tow bar set up t flat tow a TJ.
have seen the following options:
Currie Under Front Bumper Mounting Brackets - Mount under bumpber
http://currieenterprises2.reachlocal...9.aspx?id=2651
Warrior shackels but require a non factory steel bumper...
http://www.quadratec.com/products/92012_150.htm
Should I put upgrade to a front bumper with quality D rings or save the cash and go under frame bolt on?
morr1 is offline
Flat tow YJ from NH to AZ esvencarlson Trailers & Towing 1 11-03-2008 09:35 AM
Flat tow a 48 Squirrely Trailers & Towing 1 10-06-2008 11:38 AM
~ Brake assist systems ~ RikRotorhead Trailers & Towing 2 08-30-2008 12:40 AM
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 07:29 PM
Who's got Gas?? Flat-D ElPaca19 General Discussion 3 09-27-2007 04:18 AM
