Flat Tow a TJ ?? Tow Bar ?? Brake Assist?? - Page 2 - JeepForum.com
post #16 of 42 Old 02-01-2010, 12:44 AM
StvDiego
I tow my TJ with an '03 F250 Stupid Duty all the time; California mountains, desert, never a prob. I have a Blue Ox tow bar, great bar, very, very heavy, runs about $300, pulls the same as a $100 tow bar. When the new bumper is built I'll dump the Blue Ox and use my Pep Boys folding tow bar and my $9 on sale Harbor Freight lights.
True about the F-250 and weight. Last trip I had a D44 and two D30's in the bed, a couple of lift kits and various other parts, major difference in handling. Toss some weight in the bed or keep an eye out for Velvet Ride shackles.
StvDiego is offline
post #17 of 42 Old 02-01-2010, 10:16 PM
chadsmeltzer
chadsmeltzer's Avatar
I have driven this setup a couple thousand miles. The quads in the bed help the ride somewhat, and you really can't tell the Jeep is there when stopping. We also flat towed that TJ with a WJ and stopping it is very noticeable and ended up warping rotors. With the F-250, there is no need for aux brakes at all, until we use the 30ft gooseneck
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #18 of 42 Old 02-03-2010, 07:16 AM
jdub36
Where do you guys stick the magnet lights? I am trying to figure out where the best spot is on a TJ with soft top.
thanks,
JW
jdub36 is offline
post #19 of 42 Old 02-03-2010, 08:40 AM
Kris_Kris
thanks,
JW
I used the magnetic ones for a while but there was no good place to put them.
I installed a 2nd set of light bulbs in the factory tail lights and wired them directly to a trailer plug on the front of the jeep. When they are on, you can not tell the difference between them and the factory lights. This way the lights are always there and ready to go.
Kris_Kris is offline
post #20 of 42 Old 02-03-2010, 10:24 AM
chadsmeltzer
thanks,
JW
I just stick them on the rear bumper. I have hit some pretty big bumps and gone thousands of miles like that and never even had one budge. Just make sure the bumper is fairly clean first.
post #21 of 42 Old 02-03-2010, 11:04 AM
jdub36
ok i will have to pick up a set and try them before my big trip.
thanks,
JW
jdub36 is offline
post #22 of 42 Old 02-03-2010, 11:08 AM
chadsmeltzer
thanks,
JW
Harbor Freight has some for around $20. Only thing I don't like is they are just barely long enough. The LED version is nice too, I got them on sale for around $15. Only complaint about them is when the lights are on, the blinker is sorta hard to see. (I think that's what is was, its been a few months.)
post #23 of 42 Old 02-03-2010, 11:48 AM
StvDiego
x2, this worked out very well, until i got LED taillights. Installed a bulb socket in the factory light, used a trailer wiring harness from WallyWorld, mounted a plug on the front grill, ran the wires past the radiator thru the engine compartment/firewall and along the driver's inside of the tub, and it was an easy plug-in.
I have the Harbor Freight magnet lights now, $9 on sale with coupon. They're definitely cheap, the magnets almost stick to metal and I had to replace the bulbs immediately. I epoxied new magnets on and stick them on the hi-lift jack that runs across the tire/can carrier. Before that I bungee corded them on. A couple of friends I run with use this method, bungee cord to the top of the factory tail lights and one guy epoxied a metal plate to the inside of his factory lights and then uses the magnets to hold them on.
StvDiego is offline
post #24 of 42 Old 02-03-2010, 06:10 PM Thread Starter
Mike_Motorbike
How about safety chains?
The tow-bar to truck is self explanatory . Butt The Harbor Freight tow bar has a loop for safety chains from the tow bar to the Jeep....
Where do you put those chains?
I see a couple slots under the bumper for tie down points .... Do you get a hook for the chain and put them there?
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #25 of 42 Old 02-03-2010, 06:20 PM
chadsmeltzer
Do you have drings? You could hook them there. Mine doesn't have anything to hook to the Jeep, but mine is way overbuilt. If the towbar comes off my Jeep, I have much bigger issues to deal with.
post #26 of 42 Old 02-03-2010, 07:41 PM Thread Starter
Mike_Motorbike
Instead of mounting the bracket to the front of the bumper can I bolt it to the bottom/ underside of the bumper where the bumper bolts on?
post #27 of 42 Old 02-03-2010, 07:44 PM
92 Green YJ
92 Green YJ's Avatar
i dont see why not. Though i'd be concerned with that hurting your ground clearance. I welded my brackets for my Harbor Freight tow bar right to the front of my bumper.
For safety chains I just hook the ones from the tow bar to the Jeep up to my D-rings on my front bumper
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #28 of 42 Old 02-03-2010, 08:07 PM Thread Starter
Mike_Motorbike
Hmm ... no D rings stock bumper...
post #29 of 42 Old 02-11-2010, 11:36 PM Thread Starter
Mike_Motorbike
Tow bars on sale at Harbor freight. Feb 11-20 something.....
I got it for $38 it is on sale for $49 and I had a coupon for 20% off.
And Truckers 3/8" X 14' chain on sale for $14 . That'll make a nice safety chain.
And Magnetic tow lights $19
post #30 of 42 Old 03-03-2010, 02:11 PM Thread Starter
Mike_Motorbike
I made some kick a$$ tow bar mounts out of stainless heavy gauge 2" square tubing . That bolt too the bottom of the frame rail .
I can't wait to get picks and share....
Flat tow YJ from NH to AZ esvencarlson Trailers & Towing 1 11-03-2008 09:35 AM
Flat tow a 48 Squirrely Trailers & Towing 1 10-06-2008 11:38 AM
~ Brake assist systems ~ RikRotorhead Trailers & Towing 2 08-30-2008 12:40 AM
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 07:29 PM
Who's got Gas?? Flat-D ElPaca19 General Discussion 3 09-27-2007 04:18 AM
