Quantcast Extra Trailer Lights... - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > General > Tow Rigs & Towing > Extra Trailer Lights...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 12-11-2006, 09:35 PM   #1
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I was wondering if anyone has put lights that shine down along the side of the trailer to light up the tires and the side of the road to help see the edge of the road better. I was thinking about putting liscense plate lights that shine down between my wheels to shine down to help at night, or right in front of the front tire. any ideas? Just was a thought.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ Rear Dana 44 for sale
(4) 5x4.5 steel beadlocks
3 11"& 2 13" BBCS shocks
Big Daddy Offroad HD tie Rod
JeepRocks86 is offline   Reply With Quote
Unread 01-06-2007, 06:48 AM   #2
badge1236
1978 CJ7
You might want to check with the dot about the legality of something like this. I am not sure if there are laws mentioning this type of trailer lighting but it would be bad to do it and find out later that it is illegal.
'78 cj-7, 258, twin stick dana 300 transfer case, NV3550 transmission, scout d44 axles with detroit truetrac, 4.09 gears, black diamond 3.5 inch lift. The rest is yet to come.
badge1236 is offline   Reply With Quote
Unread 09-21-2007, 09:05 PM   #3
wingless
My trailer has the wheels outside the bed. It came with the turn / brake lights behind the wheel and marker lights on the front corner of the bed.
When I re-wired the trailer I added amber marker lights in front of the wheels. It is VERY helpful at night. I can see the trailer centered between the lines. I can also see clearance passing objects.
One other problem when towing is the dough-heads that jump into the lane, once my vehicle clears their front bumper. It doesn't matter, to them, that a trailer is attached to my hitch. I think the added marker lamps helps to increase the trailer visibility.
wingless is offline   Reply With Quote
Unread 09-21-2007, 10:06 PM   #4
JeepRocks86
i ended up adding 4 small brake lights and 4 small amber lights on the side. I think i'm going to add some amber lights on the rear for running lights.
My Build Thread.
For Sale:
Unread 09-22-2007, 04:55 AM   #5
wingless
It may be that additional running lights, added to the rear edge of the trailer, must be red and not amber. That should be verified.
Unread 09-22-2007, 07:36 AM   #6
JeepRocks86
probably is true. I may add more red lights to run a running lights.
My Build Thread.
For Sale:
Unread 09-22-2007, 03:32 PM   #7
Jesse-James
1989 XJ Cherokee
Rear corner and any rear facing lights must be red. The rest must be amber. and I am not aware of a state that would let you put lights facing down to light up the road.
Live in SE WI? -----> Brew City Crawlers
BUILT XJ FOR SALE
Jesse-James is offline   Reply With Quote
Unread 09-22-2007, 06:54 PM   #8
wingless
The lights I added in front of my wheels have the normal horizontal orientation, but the projection angle is sufficient to illuminate the lane markers, which I find useful.
Without those lights I have almost no visibility of the trailer at night, except when passing street lights, so this addition works for me.
