double towing - JeepForum.com
post #1 of 29 Old 06-05-2011, 04:37 AM Thread Starter
honker
double towing
Has anyone ever flat towed their jeep behind a fifth wheel camp trailer. I have towed my quads quite often without any problems behind my fifth wheel. But not my jeep.
honker is offline
post #2 of 29 Old 06-05-2011, 10:03 AM
MPond
I haven't done it personally, but I spent about 20 minutes talking to a guy next to me at a truck stop who was pulling his YJ behind a 5-er toy hauler.
He commented that, legal or not, there were a lot of highway patrolmen out there who didn't know the law when it came to towing doubles, and he'd been stopped multiple times. He ended up carrying a copy of the California Vehicle Code section that refers to doubles. Luckily, he'd never been cited, as the officer's couldn't come up with a code violation to use on the citation.
The other consideration is the length of your 5-er. I have a 38' Next Level, and combined with the length of my crew-cab long bed dually, I can't add the TJ behind it without going over the max length limit.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #3 of 29 Old 06-05-2011, 10:14 AM Thread Starter
honker
My Fifth wheel is a 30 footer and short bed crew cab. In Utah max length is 65 feet. So I should be ok. I was just wondering how good they pulled?
honker is offline
post #4 of 29 Old 06-05-2011, 10:35 AM
MPond
How heavy is your 30' 5-er? I'd only consider trying it if it outweighs your Jeep by a good margin - at least a couple thousand pounds, for the sake of stability.
Edit - I've towed my Jeep behind my 38' Diesel Pusher, and don't even notice it back there. I've also towed it behind my Suburban 2500, and it's noticable, but plenty stable. But my Suburban is a good 1500 - 2000 lbs heaviery than my LJ. I wouldn't even consider it if the 5-er is lighter or the same weight as the Jeep.
MPond is offline
post #5 of 29 Old 06-05-2011, 11:03 AM Thread Starter
honker
My fifth wheel is almost 7000 lbs.
honker is offline
post #6 of 29 Old 06-05-2011, 11:04 AM Thread Starter
honker
But that's a good point. Thank you
honker is offline
post #7 of 29 Old 06-05-2011, 04:35 PM
MPond
If the length isn't an issue, and the combined weight of the 5-er and the Jeep aren't an issue for the GCWR of your tow vehicle, then I'd be inclined to try it.
Good luck to you.
MPond is offline
post #8 of 29 Old 06-25-2011, 02:22 PM
drewrw
Other double tow question
What about flat towing a TJ behind a Hemi, and the TJ towing a small 14-foot Dory (with only a 15HP engine, all very lighweight)?? Anyone know the deal with that situation?? Thanks.
drewrw is offline
post #9 of 29 Old 06-27-2011, 07:51 PM
chadsmeltzer
chadsmeltzer's Avatar
Probably not legal. Usually the first trailer must be a 5th wheel designed for camping.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #10 of 29 Old 06-27-2011, 08:06 PM
Kredtj
My cousin who is a firefighter in Riverside City, CA flat tows behind his fifth wheel all the time. He has a 05 LJ, so he has figured out everything like tow capacity and length. I agree with MPond though, if it is legal in your area, carry the vehicle codes with you so that any unknowing patrolmen will understand.
Kredtj is offline
post #11 of 29 Old 06-28-2011, 11:43 PM
drewrw
The only thing is my Hemi is in a Grand Cherokee, so no 5th wheel option.... any one know if it's a good idea?.... I already know the double tow law in NY and I fit under 65" so it's legal, but is the Cherokee w/the Hemi able?
drewrw is offline
post #12 of 29 Old 06-30-2011, 12:10 AM
scrambled
You shouldn't tow a tj with a grand period. The wheelbase is to short. You are just asking for disaster trying to tow a double.
2014 JKU Rubicon X-2002 Grand Cherokee Limited
Past: 2003 TJ Rubicon, 2006 LJ Rubicon Rubitrux
scrambled is offline
post #13 of 29 Old 07-01-2011, 06:50 PM
drewrw
Well I have already towed the TJ on a 16ft car hauler with the Grand for a total of about 9 hours and had absolutely no problems. But I assume there's a difference with a flat tow?
drewrw is offline
post #14 of 29 Old 07-02-2011, 08:58 AM
zooby
The biggest issue your going to have flat towing behind a Grand is stopping. If you add a way for the towed vehicle to apply the brakes when you stop then the only issue is how happy the Grand's trans and rear diff will be pulling all that weight.
zooby is offline
post #15 of 29 Old 07-03-2011, 03:28 PM
drewrw
So I could get a supplementary braking system to help with the stopping, I've looked into those, although not cheap. And the Cherokee w/Hemi is rated to tow up to 7,200 punds and The TJ is less than 1/2 of that. So maybe I'll be okay with that. But probably a bad idea to have the TJ pulling the 14-foot boat. Thanks.
drewrw is offline
towing double nwco4x4 Trailers & Towing 6 06-04-2011 10:59 PM
Double Take, What The.... Mobile_Homie General Discussion 5 09-18-2009 10:23 AM
Double You Tea Eff Hoobly_Goob General Discussion 8 07-29-2009 06:30 PM
Double clutching COBRA COMMAND General Discussion 44 06-18-2006 10:31 PM
Double towing GlennC General Discussion 17 02-24-2006 01:12 PM
