Does anybodys tow with a cherokee - JeepForum.com
post #1 of 9 Old 11-10-2012, 09:15 PM Thread Starter
kidsthesedays
I bought a xj looking to hunt in it but I also need it to tow a camper does anyone else tow with there's long distances
kidsthesedays is offline
post #2 of 9 Old 11-10-2012, 09:21 PM
dwzook
1995 XJ Cherokee
it doesn't pull a car trailer and a nissan 240sx very well! lol had to tow my friend back from a town like 2 hours away. couldn't go past 55 without it feeling VERY unstable, and running pretty hot. if your camper is anywhere around 5000+lbs, the don't do it. If it's below that, should do fine.
dwzook is offline
post #3 of 9 Old 11-10-2012, 09:29 PM
Ross
I had a 01 grand and a 3k camper. I dumped the grand within the year, it sucked as a tow vehicle for my camper. Before that I pulled a cargo trailer loaded with about 2500 lbs about 1800 miles (it didn't stick above the jeep) and the grand did fine.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #4 of 9 Old 11-13-2012, 09:47 AM
smittyboy
I got an 04 wj and I typically tow 2 jetskis everywhere with the only issue is getting a small bounce from the short wheel base. Towing is fine but not always comfortable
smittyboy is offline
post #5 of 9 Old 11-16-2012, 12:03 AM
Indy
Indy's Avatar
Ive flat towed m samurai, wasnt fun. Towed a douple pop up campers, no problems. Ho4.7 with tow package.
I'm the only gay eskimo.
Indy is offline
post #6 of 9 Old 11-18-2012, 03:18 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Unless you did a motor swap, that was a grand cherokee
I would not tow anything over 2k with an XJ.
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline
post #7 of 9 Old 11-23-2012, 08:45 AM
Indy
Indy's Avatar
Ya 2004 gc so worthless info to the op . There is a big difference in the amount of noise you get from the hitch with a framed truck vs the unibody. It took some getting used to.
Indy is offline
post #8 of 9 Old 11-24-2012, 03:51 AM
GregB_00XJ
A Cherokee (XJ) with the 4.0L IL6 and a full tow package including electric brake kit, trans cooler, HD cooling and the appropriate hitch is rated to tow 5000# IIRC. I would however NOT tow 5000# with mine, but I do tow a camping trailer that loaded is rated at around 2700#. It tows it like a champ, stops great and never breaks a sweat.
I say 3500# is a comfortable maximum. It can pull a lot more, but stopping becomes an issue as well as sway. I would NOT tow anything over 1500-2000# without electric brakes that work well. Oh and the tongue weight I believe is limited to 300#, but that is a lot for an XJ.
Proper loading is key, as is suspension setup. Towing 2000# with an XJ with the trailer improperly loaded on stock suspension will be a handful to say the least. If you are hauling a trailer for camping, and it falls within those guidelines, you should be GTG. As always, make sure your XJ is up to the task...
Cooling
Trans Cooler (manual can tow less than the auto)
brakes
engine
Diffs (requires heavier synthetic fluid)
etc
Your owners manual has most of this in there for your reading pleasure.
2000 Jeep Cherokee Classic XJ - 2005 Jeep Grand Cherokee LTD 5.7L WK - CDN M101 1/4 Ton Trailer
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #9 of 9 Old 11-28-2012, 10:07 PM
MoZee
I tow a 12 foot pop up with mine. It's not terrible
Camper weighs about 2k pounds
MoZee is offline
