Daily Driver/tj tow - Page 3 - JeepForum.com
post #31 of 36 Old 02-15-2012, 12:03 PM
wilson1010
Originally Posted by wilson1010 View Post
Second, a cubic yard of gravel weighs like 4000 pounds. How is 4000 lb for tongue weight?
4000 lb tounge weight on a 4000 lb load? Should be between 400 and 600 lbs. Well within the capabilities of any truck you can slap a class 3 hitch on.
I would urge you to consider exactly why you need a PU in the first place if you don't need a 12,000 - 16,000 towing capacity.
I bought a new mattress on Sunday. It wouldn't fit in the Tahoe. It certainly didn't fit in the Jeep. My car is obviously too small too. Did I need at 12K - 16K towing capacity to get it home?
Originally Posted by Jason View Post
Look harder. Head gaskets, stretched head bolts, EGR issues, as well as the cost to repair or prevent these issues.4000 lb tounge weight on a 4000 lb load? Should be between 400 and 600 lbs. Well within the capabilities of any truck you can slap a class 3 hitch on.
Oh boy are you confused.
A 1/2 ton pickup has a bed load capacity of about 1500 pounds. If one put a cubic yard of gravel or dirt in the bed the equivalent tongue weight would be tooo much. Are you thinking that one could put a cubic yard of gravel in a 1/2 pickup?
As for your mattress, I think it would be just as safe strapped to the top of a Tahoe than hanging out of the bed of your pickup.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #32 of 36 Old 02-15-2012, 12:04 PM
Jason
Originally Posted by Boreal View Post
The 6.0 he was referring to was the Chevy gasser, which seems to be a solid engine. It's also available in a 1/2 ton, so he wouldn't need to jump to a 3/4 ton to get it.
I have a 6.0 diesel and you are spot on about those
Righto, thought he was talking about the Powerstroke 6.0. I looked at them, as they were in my price range, but the issues with the early ones scared me off. They made decent power, but the realiablity and the cost to "bulletproof" them before they had issues, or repair after they had issues kept me from buying. I guess the later ones (05 - 06) are better.
The Chevy gas 6.0 is a beasty good motor. The only real problem with those is that they are thirsty.
Jason is offline
post #33 of 36 Old 02-15-2012, 12:30 PM
Jason
The only thing I was confused about was your confusing statement about two ton tongue weights. Payload and trailer tongue weights are not the same thing. Furthermore, the OP never mentioned 4000 lbs of gravel. If that is his need, then this would be an entirely different conversation.
I'd rather slide a mattress in the back of a truck than try to hoist then tie it to the roof of a Tahoe or similar vehicle. I had a Bronco for years. My constant complaint was the fixed roof over the cargo area. There were too many occasions I needed to carry something too tall to fit in the truck. I had to call someone with a "real truck" to pick it up for me.
It rather seems you are confused about the OP's needs. Bigger is not always better.
Jason is offline
post #34 of 36 Old 02-15-2012, 12:53 PM
wilson1010
I heard from you a reason to have a pickup. Not a very good one - a mattress - but I didn't actually hear anything from the OP that indicated a pickup. I was pointing out what causes many people to choose a pickup which actually turns out not to be a good idea - hauling gravel or top soil or even mulch. A 1/2 ton pickup is not capable of carrying meaningful amounts of gravel or dirt or even mulch.
It is capable of carrying a mattress which is apparently why you have one.
I was suggesting to the OP that he think about a Tahoe or equivalent which seemed to fit his needs more than a pickup (10 mile daily commute, occasional towing of 6000 pounds or less). I have had about 10 pickup trucks, so I do find them useful, but not typically the 1/2 ton variety.
post #35 of 36 Old 02-15-2012, 01:09 PM
ajmorell
ajmorell's Avatar
I agree with what you are saying here. The usefulness of a 1/2 ton is limited from the payload point of view but there have been substantial increases in the towing capabilities of 1/2 tons as of late. It really boils down to lifestyle. A Tahoe or Expedition is a pretty capable tow rig if equipped properly but you do lose that ability to carry oversize cargo, whether it be 2x4s, refrigerators, mattresses, etc. I've strapped a box spring to the top of my ZJ, getting anything with any significant weight on the roof of any SUV is nothing short of a pain in the ***.
ajmorell is offline
post #36 of 36 Old 02-15-2012, 03:42 PM
wilson1010
I also have a full sized cargo van, an older Chevy G20 (3/4 ton) 350 white box carpeted inside which I have found to be far more useful than my pickups. I'd agree that you can't put a queen sized mattress in it, but for most other things it is much more useful. I have a set of ramps, so the quad, the ride-on mowers, go in. And, you can sleep in it if you are out in the rain. It will tow a TJ and a trailer as good as a 1/2 ton pickup and you don't have to worry about people taking your stuff when you are out on the trail. Just lock it up. If you buy a bunch of lumber at Lowes, it stays dry and unmolested until you use it. I had them put a pallet of cement blocks in it recently. Its standard length and you can put a 10 foot lumber on the floor in it with the doors closed. If you angle, you can put in 12 footers. I can't tell you how many times I had to move camp inside the van.
All of that said, there is nothing to compare with a modern diesel tow rig.
Wrecked my daily driver. Preparing for 60 mile daily commute in my YJ. soonermatt YJ Wrangler Technical Forum 20 10-18-2011 09:36 PM
Daily Driver: CJ or YJ? dart1516 YJ Wrangler Technical Forum 37 08-16-2010 03:43 PM
Its not a daily driver corvetteguy YJ Wrangler Technical Forum 8 11-09-2008 10:39 PM
daily driver SOA sasquachYJ YJ Wrangler Technical Forum 9 11-25-2007 06:02 PM
Daily Driver? BruceB TJ Wrangler Technical Forum 21 05-09-2004 02:29 PM
