cargo trailer axle change - JeepForum.com
post #1 of 2 Old 05-30-2012, 11:32 AM Thread Starter
Ross
I want to run the same size tires on my 5X10 foot cargo trailer as my TJ. I have a set of steel for my TJ with 3.75 BS I have run on my TJ and some 33X12.50 TrXus MTs.
I am also considering doing a spring over on the trailer but not sure if that could cause stability issues or problems if I load up the trailer?
I want to get the axles slight wider than the previous one so I don't have any issues with back spacing.
I am looking for advice from anybody here that can offer it.
I believe my Jeep bolt pattern is 5 on 4.5, this axle is that pattern, any thoughts on this axle? They have the hub also in star pattern. Is one hub design better than the other?
88 x 74 Idler Axle, 3,500 Lbs
http://www.orschelnfarmhome.com/88-x-74-idler-axle-3500-lbs/ctl16754/cp57927/si5175819/cl1/
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #2 of 2 Old 06-06-2012, 11:44 PM
TrailersPlus
Give me a call tomorrow while I'm at work and I should be able to pass along some advice.
I'm usually there by ~8:45am to ~5:45pm Tues - Sat.
TrailersPlus is offline
Cargo Trailer djsrtr Trailers & Towing 5 12-09-2010 07:45 AM
Towing 8' Cargo Trailer newmin Trailers & Towing 8 08-30-2009 07:26 AM
Trailer Axle mickmeister Trailers & Towing 2 03-23-2009 09:13 PM
Ever heard of an MP1001 cargo trailer? Hilldweller Trailers & Towing 0 08-14-2008 01:42 PM
trailer axle? VegasJeep General Discussion 8 12-27-2005 08:22 AM
