Can I flat tow my wrangler with different gear ratio - JeepForum.com
post #1 of 13 Old 11-07-2011, 09:15 PM Thread Starter
Kmariano
I just bought my 1994 jeep wrangler. The previous owner changed the rear axle to a Dana 44 and didn't change the front gear ratio on the stock Dana 30. My question is if it's ok to flat tow my jeep like this until I get the money to fix it right.
Kmariano is offline
post #2 of 13 Old 11-08-2011, 07:24 PM
Indy
Indy's Avatar
Pull the front driveshaft and its not an issue. Never flat towed my old yj so don't know the particulars to it. Never pulled a shaft either so take that idea as just an idea.
I'm the only gay eskimo.
Indy is offline
post #3 of 13 Old 11-08-2011, 08:42 PM
wilson1010
Your post is confusing. Are you saying that the front and rear doffs have different gear ratios? That means you can't drive in 4wd. You know that, right?
Has no effect on flat towing though. Just put the transfer case in neutral.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #4 of 13 Old 11-08-2011, 09:38 PM Thread Starter
Kmariano
Yes, the front and rear diffs have diff gear ratios and I know that I can't drive in 4wd. I just want to make sure that I can flat tow it and drive it around town while I'm camping without any problems as long as I'm not in 4wd. Thanks for the replies.
Kmariano is offline
post #5 of 13 Old 11-08-2011, 09:40 PM
jake89yj
the YJ front shaft only spins when engaged into 4wd so all you really need to do is put the jeep into neutral ive flat towed my old YJ all the time (broken ) of coarse lol you will be fine.
jake89yj is offline
post #6 of 13 Old 11-09-2011, 08:33 AM
jbolty
jbolty's Avatar
That is not always true.
On most YJs (not sure if there is a cut off year) When the transfer case is in neutral the drive line is disenganged from the engine power BUT the front and rear are connected and will both turn together. This becomes a huge problem when trying to flat tow while having an aussie or other lunchbox locker in the front.
Check this thread for my issue, the explaination and the cause start in post #12.
http://www.jeepforum.com/forum/f12/y...roblem-595457/
jbolty is offline
post #7 of 13 Old 11-09-2011, 01:38 PM Thread Starter
Kmariano
I don't have a locker on the front or the rear so will it cause a problem flat towing with different ratio? And what gear do i tow the jeep in or do I keep it in nuteral?
Kmariano is offline
post #8 of 13 Old 11-09-2011, 02:15 PM
jbolty
jbolty's Avatar
Chances are you will not have any issues.
The instructions in the manual say to put the tcase in neutral and the transmission in park or 1st.
Personally I would disconnect both drive shafts from the axle end and strap them up out of the way. It will only take a couple minutes and remove any chance of problems. I did that every time I towed up until getting a tru neutral plate installed.
You can get one of these transmissioon stop off plugs from Harbor Freight for the rear unless you have an SYE installed.
Don't forget to unlock the steering wheel.
jbolty is offline
post #9 of 13 Old 11-10-2011, 02:07 AM
wilson1010
Now that is pretty darn interesting that the NP231 connects the driveshafts but not the transmission when in neutral. Just when I think there is nothing left to learn.
But, I think there will be a problem for the OP if the ratios are different. When the np231 joins front and rear, they are not spinning independently like axles on a diff. They are actually connected as though it was in 4wd if I read your references correctly. So to my thinking he has to put it in 2wd and the tranny in neutral assuming it is not an automatic which will burn up from no fluid pumping.
post #10 of 13 Old 11-10-2011, 05:09 PM Thread Starter
Kmariano
So if I disconnect both drive shafts and strap them out of the way do I still need to put the transfer case in N and the trans in 1st to tow it? Thanks guys for all the help.
Kmariano is offline
post #11 of 13 Old 11-10-2011, 05:47 PM
ajmorell
ajmorell's Avatar
No if you pull the drive shafts you can do whatever you want with the transfer case and transmission
ajmorell is offline
post #12 of 13 Old 11-14-2011, 09:32 PM Thread Starter
Kmariano
So if I get a tru neutral plat installed I don't need to put the tranny in gear or i wouldnt have to worry about disconnecting the drive shafts?
Kmariano is offline
post #13 of 13 Old 11-28-2011, 09:36 AM
jbolty
jbolty's Avatar
With the new plate you put the t-case in neutral and the transmission in gear, or Park.
jbolty is offline
Will I need a higher gear ratio to tow this. Vegamo General Discussion 63 01-16-2011 09:35 AM
gear ratio JeepN87 General Discussion 6 02-28-2009 08:44 PM
gear ration, crawl ratio, gear conversion calculator CETROV General Discussion 4 08-11-2003 02:01 PM
gear ratio question stark General Discussion 8 08-24-2002 12:11 AM
what gear ratio Rockwall General Discussion 4 11-27-2001 09:11 PM
