Building a utility trailer...Would love your thoughts -
Go Back > General > Trailers & Towing > Building a utility trailer...Would love your thoughts
Win this 2015 Jeep !!Superchips Tuning Products - 10% 0ff INSTANTLY!!6th annual beat your wife to the credit cards sale!!
Unread 10-07-2015, 09:50 PM   #1
I'm in the process of getting some supplies together for a 5' X 8' trailer build and would apprecaite any thoughts you have.
Yes, I know it's going to be cheaper to just go out and BUY a trailer, but I already have a 58" wide Dexter #3,500 axle, springs, hubs, 15" wheels, and tires, most of which was basically free. I already picked up some "flat top" fenders, and just have to pick up the steel, a 45deg-coupler, and a set of trailer lights.
The purpose of this post is to hear your thoughts on the choice of steel used to build this trailer. I'd like to build something like this pictured below, but without the ramp, and without the short steel "railing" around it. I'd rather have stake pockets with a classic 'wooden fence' around it. (removable)
I've scoured quite a few plans and came to the realization that most of these plans use angle-iron for the structure of the trailer, so the short railings are a part of the structure of the trailer and stiffen (truss) what would otherwise be a floppy mess.
My thought is to build the main frame of the trailer from 3" channel iron like this (except placed on placed on edge):
My reasoning for the use of channel is that (I think) it's more stiff, but I "aint no engineer" so would love your thoughts. This trailer doesn't need to be super heavy duty, (I already have an 18' car-hauler for the big stuff) like I said I'm just building it because we already have most of the stuff for it. (and a welder!) I figure 5'X8' is also a good size to tow behind a small/mid-size garden tractor for hauling things around the yard. I know channel is heavier than angle, but if I can get away without the upper structure, the finished trailer may actually be lighter.
Any thoughts you have are apprecaited.
I intend to live forever. So far, so good.
'99 Wrangler Sport: 2.5" Old Man Emo lift and shocks, adjustable trackbars, Quick-Disko sway links, rollin on 31" BFG A/Ts
saxart is offline   Reply With Quote Quick reply to this message
Unread 10-08-2015, 02:40 AM   #2
I'm no expert on this subject, but just an observation...
Most boat trailers are similar to what you're describing - a flat steel frame, without a rail to stiffen the structure. And they're usually made of either steel channel or steel rectangular tube.
We have 3 boat trailers in the family, each used to haul boats between 7000-8000 lbs, and each one is made of steel tube.
If steel tube / channel is strong enough for a 7000 lb boat, it should be strong enough for your utility trailer.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline   Reply With Quote Quick reply to this message
Unread 10-15-2015, 02:55 PM   #3
I have a pick up with a 5X8 foot flat bed and built a "wood fence" for it and it is frickin heavy.
Here is my trailer, I didn't build it though. I did a spring over and it has hubs that match my jeep so the tires and rims are inter changeable.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor.
Ross is online now   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
