best way to tie a jeep to a trailer - Page 5 - JeepForum.com
post #61 of 86 Old 03-14-2011, 09:43 AM
jonwood
Originally Posted by MoJeeper View Post
I like my way..Why? because it works for me and I've never had a problem. I use chains now but I'm gonna switch to straps. We use them everywhere else on farm, so they should work for my jeep.
Perfect, thats the way I do mine except I use ratchet binders on the rear, but mainly because its what I have. Im going to be buying a new trailer this month and also buying new chains and binders. I will get the same as I have now but with J hooks. Im only getting new binders because everything I have been using for the last 5 years is my Dads and he just finished rebuilding his Jeep and wants his and his trailer back
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline
post #62 of 86 Old 08-08-2011, 08:44 PM
hogelectra
Got my Jeep on the trailer but how to tie it down
Front axle maybe easy but the rear axle is hard
hogelectra is offline
post #63 of 86 Old 08-12-2011, 05:36 AM
wilson1010
One of the many problems with chaining down an axle. Ask yourself: "where would I secure a snatch strap to this Jeep" when you are considering this. Because, the forces that the axle will experience may be many times the little tug we put on a Jeep with a snatch strap. If you are like me, you will unhook the chain from the axle and put it on the chassis. It looks from the photo that you may have chained the chassis already.
BTW, is that 5/16" chain in the photo? 3/8" grade 70 is the thing. That may be it, but the photo makes it look a little small.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #64 of 86 Old 01-07-2013, 11:47 PM
TSEJEEPERS
Bumping this back up, Why? because it is important.
How do you tie your Jeep to the trailer?
Me, ratchet straps, 4 of them, crisscrossed in the front, straight in the rear, and around the axle housings.
To add a little more to think about, does your state require trailer brakes and brake away kits?
Brakes on both axles or just one?
What about trailer inspections?
Alot of us tow in alot of different states. It would be really helpful to know if we were legal or not.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #65 of 86 Old 01-07-2013, 11:53 PM
TSEJEEPERS
Another thing, I know this might be common sense, but I have seen it many times.
When strapping a vehicle down, the ancore point (at the trailer) should always be behind or in front of the vehicle. Not straight across!
post #66 of 86 Old 01-08-2013, 09:34 PM
jepp
Junior Member??
We can see that this arguement will never be fully agreed, I have used a rented car dolly a few times and as you know the front tires sitting on the dolly are secured by a heavy strap over the tires, would this be a reasonable way to tie all four tires down on a trailer? If you aren't worried about the suspension moving around, this method would not make your trailered vehicle heavier on the wheel bearings like the mechanical advantage of chain and boomers on the chassis or axles would it? just wondering.
jepp is offline
post #67 of 86 Old 01-08-2013, 11:18 PM
wilson1010
Of course it is a never ending source of disagreement because axles make an easy target for a chain or a strap despite the obvious reluctance one would have to put a strap around an axle to snatch someone out of a hole or whatnot.
Engineers among the crowd will usually choose strapping or chaining the load meaning the rig since it is ithe load that needs to be secured. And, guys with Army truck movement training will always strap to the chassis since it is specifically prohibited to strap a military truck by its axles.
Notwithstanding the disagreement, there is a lot of knowledge in the Army Tie Down Manual TEA PAM 55-20
http://www.tea.army.mil/pubs/nr/depl.../PAM_55-20.pdf
post #68 of 86 Old 01-09-2013, 11:44 AM
jonwood
Bla Bla Bla, same tired argument from Wilson
Again if Im stuck in the mud or hole, I usually cant get to my axle's
Plus if I can get to them im usually pointed up hill and winching from the axles would pull the axle upwards limiting my front traction and steering
***edit****
Also I'm not saying your wrong but your reason is weak, but if ya do go to the frame you should go to the bumpstops. If your rig can move it will.
I will always go to the axles though
jonwood is offline
post #69 of 86 Old 01-09-2013, 04:34 PM
wilson1010
Again if Im stuck in the mud or hole, I usually cant get to my axle'sPlus if I can get to them im usually pointed up hill and winching from the axles would pull the axle upwards limiting my front traction and steering
***edit****
I'm wondering whether you would be pulling my rig out of the mud hole with my strap looped around your axle. You don't like the argument because you know I'm right. Its the same thing. Exactly. Unless you believe that strapping down a rig on a trailer is less serious of force than coaxing a rig out of a little mud. I've done a lot of both and the trailer will experience much more serious forces. And, your idea of cranking down to the bump stops is just silly. Why? Your rig is bouncing all over the place if you secure by the axles.
post #70 of 86 Old 01-09-2013, 06:28 PM
Concolour
1994 ZJ
I'll just throw in here that vehicle transport drivers (the guys that haul cars from the rail head to the dealership) strap over the tires. Even the guy with a little three car trailer goes over the tires.
Concolour is offline
post #71 of 86 Old 01-11-2013, 11:39 PM
TSEJEEPERS
No it is not right. There is going to be alot more force pulling a stuck rig out than securing it to a trailer. When pulling a rig out you also have to consider how much force there is what ever it is stuck in.
When securing it to a trailer the rig is in gear, with the parking brake on. There is no where near the forces involved as pulling a vehicle out.
With my leaf springs it would be almost impossible to crank the suspension down to the bump stops.
Why would you want to put more stress on the straps or chains than needed?
From what I have seen, with a lighter vehicle, it will bounce alot more on a trailer chained or strapped to the frame than the axles.
You have to remember that the vehicles that the Armed Forces use are alot heaver than our Jeeps and do not have the suspentions made to articulate that our Jeeps are.
Also how would you go about strapping a Unibody vehicle to the trailer?
post #72 of 86 Old 01-11-2013, 11:45 PM
TSEJEEPERS
Oh and in Illinios I believe, you are required to have four straps or chains, a brake away kit, lights on all four corners, one in rear and a license plate light.
I have also heard that the trailer should be inspected every year.
That may be more for commercial trailers though.
post #73 of 86 Old 01-12-2013, 07:08 AM
wilson1010
Even though I know that this argument will never be won because the majority of guys wheeling Jeeps strap to the axles, I can try to do my part in setting the record straight. So, again, here goes.
Just about everything you have said is wrong. Sorry. But it is no wonder that the Sierra Club weenies and the DNR bureaucrats think we are all morons and just need to be controlled.
First, there is nothing near the force of pulling a rig out of a mud hole than a full on brakes to the floor stop from 70 mph. And if the stop ends up to be aided by something like a bridge abutment, or even a car in the road, it is not even close. Thats when your rig goes flying through the back window of your truck (leaving your axles strapped to your trailer) in case you were wondering.
Now, we all know that you could just about park your rig on a trailer with no straps on anything if you drive nice and nothing interesting happens. But that is not really what we are talking about is it?
And. no one needs to crank anything down to the “bump stops.” What would the point of this be? So the rig doesn’t jiggle up and down when you are going down the road? If you strap to the axles, what do you think everything above the axles is doing when you go down the road?
As for the military, this is just BS. The military rule applied to everything from a military pickup to as H1 to a semi. The fact of heavy or light doesn’t enter into the discussion but if it did, I am sure that the axles on an H! would be a lot more secure tie down than the rusty shackles on your leaf springs.
As for how to strap a unibody to a trailer, is that why you strap to the axles? Because if you had a unibody rig with no tow points that is what you would do?
post #74 of 86 Old 01-12-2013, 08:31 AM
Concolour
1994 ZJ
opcorn:
post #75 of 86 Old 01-14-2013, 01:59 PM
TSEJEEPERS
Really because I do not agree with you, you are going to start insults?
The Unibody thing was a question and I never said anything about having tow points on it.
So again I will ask, how would you tie a Unibody rig down? Since you brought it up, without tow points.
A few pictures of how you chain or strap your Cherokee would be nice.
Sorry but there is no possible way my axles are going to stay on the trailer when the rest of the Jeep goes through the back window. Even if I had rusty shackles there is still the frame mount to keep the axle under the Jeep.
Oh and hey I lived in Cin. back in the early 70s. Great town, my brother still lives there.
We lived in Kenwood.
Travel travel trailer good base for a Jeep Trailer YJames90 Trailers & Towing 7 04-15-2009 02:28 PM
New Jeep trailer 89yj General Discussion 11 05-15-2008 06:02 PM
A Trailer for My Jeep ShowmetheSign General Discussion 2 07-18-2007 03:49 PM
Tag along trailer for Jeep xxxflhrci General Discussion 0 04-26-2006 09:12 PM
