Best way ti tow my Yj with Zj - JeepForum.com
post #1 of 2 Old 08-02-2012, 11:53 AM Thread Starter
Fuddmaster
Hi I have some question about towing. Will my stock 93 ZJ with the 5.2l tow my stock 94 YJ 2.5l with hard top? I live in Cleveland and have a place to store it and work on it in the Toledo area. Was wondering if I use a tow dolly if it will work? Or if I use have to use a trailer. I will be getting one or the other from u-haul. I just want to know if it is doable. Thanks in advance
Fuddmaster is offline
post #2 of 2 Old 08-03-2012, 06:34 PM
MPond
You can't tow a YJ on a dolly unless you disconnect the rear driveshaft (assuming you tow from the front). You'd be better off with a trailer or using a tow bar.
Personally, I wouldn't want to tow a YJ with something as light as a ZJ, but that's just my personal preference. Depending on the hitch rating and towing capacity of your ZJ, it might be possible. You'll have to check your manual for those specs.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
