Base plates for flat towing - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Base plates for flat towing
Paracord grab handles, door limiting, etc at JeepHut.comRough Country Deals at JeepHut.comNew! JK/U skid plate system.
Unread 01-12-2015, 06:05 PM   #1
lathe11
Hey all, bought a 2008 wrangler X with after market steel bumpers, now I have to get base plates for it, so I can tow it behind motor home. Looked at another factory jeep bumper and didn't look like the mounting was any different and the bottom of both were about the same Distance on the frame rails. Has anyone set up there wrangler to tow behind motor home with the big steel bumper and what base plates did you have to go with ?? Thanks
lathe11 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 06:56 PM   #2
JMelton
You might want to join and post on the Dinghy towing area on www.rv.net/forum. There are lots of folk who have been there and done that. We also need more information including some pictures. Lots of brands of bumpers and tow systems.
JMelton is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 09:11 PM   #3
lathe11
This for the roadmaster base plates, they would mount on the frame rails, not an issue except them clearing the steel bumper vs. the stock bumper?? Have been towing wranglers for years no problems, just trying to see if someone on this forum may have encounter this and what they used??
Unread 01-12-2015, 09:24 PM   #4
JLC08JK
What was I thinking?
JLC08JK's Avatar
Welcome to the Club
We do have a towing section where you might find more info. > http://www.jeepforum.com/forum/f104/
In the mean time I added a bit to your title to make your question a little more clear.
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 10:41 AM   #5
rcsutton
2010 JK Wrangler
RockHard has what you need
2010 2 door JK Red Rubicon.
rcsutton is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 07:23 PM   #6
lathe11
base plates HELP
HI, purchased a 2008 wrangler X with High Rock bumper , went to order base plates for my roadmaster tow bar and no one seem to know what set of base plates will work with this bumper. Any one out there that is towing a JK behind a motor home run into this and what plate were used ?? Thanks
Unread 01-13-2015, 07:35 PM   #7
lathe11
Where can I find them ?? Are they the manufactor or a retail company??
Unread 01-13-2015, 07:53 PM   #8
ncb
http://www.rockhard4x4.com/mobile/Category.aspx?id=416
ncb is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 10:48 PM   #9
1222
Make mine a Jeep!
1222's Avatar
Moved from JK tech.
1222 is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 09:50 PM   #10
lathe11
Thank you !! Rock Hard owner James was a great help, and a pleasure to talk with!!
