Axle truss tie down ideas - JeepForum.com
post #1 of 12 Old 08-16-2015, 04:41 PM Thread Starter
Havasu Living
1980 CJ7
I'm buying a truck and trailer soon to hit more trails in AZ. Need ideas on tie down points for this AMC 20 with the truss. I was thinking of welding d-rings next to the diff. The plate is 3/16".
80 CJ7 5.0 Dual Exhaust, T176, D300, D30 w/ true trac, AMC 20 w/ ARB 4.56 gears, York OBA, Hydroboost
Havasu Living is offline
post #2 of 12 Old 08-16-2015, 07:27 PM
wilson1010
Would you snatch someone out of a mud hole with a strap tied to your axle?
Correct me if I am wrong, but isn't the only thing holding your axle on that rig, the little rusty bolt that goes through the end of the leaf spring and bolts to the spring shackle? Consider that the forces that are applied to your tie downs are a large multiple of snatching a person out of a mudhole if you are unfortunate enough to actually need your rig to stay tied down, like say a quick stop against the rear of a fully loaded semi trailer or whatnot.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #3 of 12 Old 08-17-2015, 04:16 PM
Fourtrail
1974 CJ6
Yes you would be good to weld on d-rings to the truss. Also you want to be as close to the center line of the axle so you do not put much rotational twist into the spring when you tie the Jeep down. But I would weld on a tab to attach the d-ring to, then only put on the d-ring when you are trailering. The last thing I want is another thing banging around under the jeep while offroad.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 12 Old 08-17-2015, 04:21 PM
Fourtrail
1974 CJ6
You are wrong. If that little bolt holding the axle to the rig was such a problem, then every time you slam on the brakes, the body/frame would come free from the axles and fly off.
post #5 of 12 Old 08-17-2015, 07:23 PM
wilson1010
Oh, there is something else holding the axle on the rig? I wonder what it is?
Actually, despite the sound, locking up the brakes is not much of a stop. My groceries don't even move off the rear seat. Let's see . . . 60 mph and it takes 185 feet to stop. Hmm, wonder what the forces would be it it took, say 12 feet to stop like against the rear end of a fully loaded semi? My guess is the OP will be wearing a CJ7 somewhere around the back of his head.
post #6 of 12 Old 08-30-2015, 08:08 PM
329892 - Deactivated
Guest
this..
several commercial systems out there,
329892 - Deactivated is offline
post #7 of 12 Old 08-30-2015, 08:12 PM
Guest
check out the next tow truck or deck truck that drives by. anything with solid axles get a j-hook over the axle and chained to the deck.
post #8 of 12 Old 09-01-2015, 10:10 PM Thread Starter
Havasu Living
1980 CJ7
Originally Posted by billiebob View Post
this..
Yeah I'm going with this.
post #9 of 12 Old 09-06-2015, 11:48 AM
222Doc
222Doc's Avatar
Who you run with H L? Parker is up and running now, Splash prep. Bull head first meeting this month. i was thinking of doing Moss(Kingman) the hard way end of the month. have to bring it up at the BH meeting but should be a fairly cool day up there. As well as pre running trails in parker.
Just need the weather to get wee bit cooler.
Everyone ties them down by the axles. I have never seen a trail jeep tied by the tires EVER< Even at the splash were we might see a few hundred in tow.
222Doc is online now
post #10 of 12 Old 09-07-2015, 06:58 AM
wilson1010
On a bet, a couple of Labor Day Weekends ago, we counted the tie downs on trailers at Haspin and it was about 50-50, tied down by tow points on the rig or by the axles. There were about 40 rigs on trailers. There were a couple tied down looped through the wheels. Obviously the tow points are the best tie downs. All of the ATV's were tied down by tow points or across the frame. One can easily bend an axle tube with a chain binder.
post #11 of 12 Old 09-07-2015, 06:15 PM Thread Starter
Havasu Living
1980 CJ7
I'm not running with anyone. Another month and the weather will be perfect until next July,
post #12 of 12 Old 12-24-2015, 05:00 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Something to consider with a Jeep on a trailer. If you tie it down by the frame you need to make sure you get it to the bump stops. If not when you hit a bump the rig will bounce, putting slack in the straps then shocking them.
RnEmOvr is offline
