Axle straps on a TJ - JeepForum.com
post #1 of 17 Old 03-07-2012, 03:51 PM Thread Starter
Weeeee
Axle straps on a TJ
I am considering using axles straps to tie down my TJ on a trailer. My main concern is the rear axle, and where can I use the axle strap without crushing the brake line since the line is right on top of the axle tube.
Any input from those that use axle straps?
Weeeee is offline
post #2 of 17 Old 03-07-2012, 04:31 PM
Foundrydude
Loop em around the trailing arm brackets
Foundrydude is offline
post #3 of 17 Old 03-07-2012, 04:39 PM Thread Starter
Weeeee
Are you talking about the lower control arm mounts, is so wouldn't that put a ton of stress on the CA bushings(in my case Johnny Joints) or end up cutting the strap?
Weeeee is offline
post #4 of 17 Old 03-07-2012, 05:37 PM
wilson1010
Just put the strap wherever you would put a snatch strap if you were snatching it out of the mud.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #5 of 17 Old 03-07-2012, 05:42 PM Thread Starter
Weeeee
Well that would be on a d-ring on the bumper, I would never use a snatch strap on an axle.
Weeeee is offline
post #6 of 17 Old 03-07-2012, 06:26 PM
wilson1010
My point exactly. The forces that cause you to tie the Jeep down securely are much the same as those that would be applied to snatch you out of the mud, only more so. If it was not for the possibility that someone might run into the back of your trailer, or a wheel come off or the tow rig hits something, you could just put it gear and pull on the parking brake and it would stay right about where you put it.
post #7 of 17 Old 03-07-2012, 06:28 PM Thread Starter
Weeeee
My point exactly. The forces that cause you to tie the Jeep down securely are much the same as those that would be applied to snatch you out of the mud.
But that doesn't answer my question, I asked about using axle straps.
Weeeee is offline
post #8 of 17 Old 03-07-2012, 06:35 PM
wilson1010
There is no good place to secure an axle strap because you will certainly damage the suspension if anything interesting happens, and you may find the axles sitting on the trailer and your jeep rolling around in the median if that interesting thing is serious. Most people don't care because 99.999999% of the time, nothing interesting happens.
post #9 of 17 Old 03-07-2012, 06:43 PM Thread Starter
Weeeee
pointless to even ask this here because someone always wants to debate axle vs frame or recovery point, never mind.
Weeeee is offline
post #10 of 17 Old 03-07-2012, 08:03 PM
wilson1010
If you didn't get the point, let me say it for your really simply.
It doesn't matter one tiny bit where you put the straps as long as you are not crushing a brake line. They won't hold the Jeep on the trailer if anything happens no matter where they are and a 2" ratchet strap can only put a few hundred pounds of force on the axle so you can't hurt anything except the brake line.
post #11 of 17 Old 03-07-2012, 09:11 PM
jonwood
Instead of a strap you can use a J hook and come from under the axle tube. I have done it that way and it works great and is super fast.
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline
post #12 of 17 Old 03-07-2012, 10:03 PM
Foundrydude
Just hook em to your axle brackets. Not to the trailing arms. Straps should have a protective sleeve anyway to protect them from edges.
Many axles also have a spot where the brake line steps off the axle and you can put the strap under the lines.
If you still can't find a way to do the axle straps just throw the chain or ratchet strap's hook over the axle bracket.
post #13 of 17 Old 03-08-2012, 11:25 AM Thread Starter
Weeeee
Sorry for my cranky responses last night, had a bad day... FYI - I am considering the axle straps as additional tie downs in conjunction with what I currently use of a 4 point tie down that I connect to recovery points on the jeep. Just looking for additional safety for long hauls in an enclosed trailer.
I will have to fool around with the axle straps and see if I can find a good spot on the rear axle that doesn't crush the brake lines, I just may be able to squeeze it underneath.
Thanks all.
Weeeee is offline
post #14 of 17 Old 03-08-2012, 07:22 PM
Jason
I am able to slip my axle straps under the brake lines on the rear axle with no trouble. Just takes a second of fiddling around to get it under there.
Jason is offline
post #15 of 17 Old 03-09-2012, 05:03 AM
wilson1010
Thanks all.
I'm cranky all the time, but I am sorry to have visited that on you.
Your plan is just fine. With ratchet straps you can probably crush the brake lines if they get squeezed by hitting a bump so I would follow the above advice and see if you can loop them under the lines. If you are using chains on the axles, be careful with any chain binders. A threaded ratched chain binder can and will bend your axle tubes.
Recovery Straps SHeadrick General Discussion 30 04-01-2009 08:58 AM
Anyone make their own tow straps? bigken98 General Discussion 21 08-28-2007 11:08 AM
Tie down straps learfxr Trailers & Towing 6 11-29-2006 02:38 PM
What size tow straps? ScratchMan General Discussion 2 04-24-2005 12:00 AM
tow straps anyone?? franco802 General Discussion 18 12-01-2004 09:34 PM
