Assuming... - JeepForum.com
post #1 of 7 Old 12-02-2008, 05:07 AM Thread Starter
Famous337
Assuming...
Assuming that you droped a Hemi in a new JK unlimited, your tow rating would go up, correct? The reason it is only rated at 3500 besides to CYA is because of the weak enginge?
04 Freedom edition 4.7HO
Past:
2001 XJ 60th 265's
99 TJ. 32's
Famous337 is offline
post #2 of 7 Old 12-02-2008, 06:17 AM
Dryfter
From what I've read the engine is only part of the problem. You have to consider the wheel base of the vehicle also. That's why the unlimited has a higher toe rate than the regular.
Dryfter is offline
post #3 of 7 Old 12-02-2008, 07:09 AM
2005X
alot of things are considered, engine, brakes, gearing, wheel base, weight of the vehicle
2005X is offline
post #4 of 7 Old 12-02-2008, 10:36 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Frame and receiver mounting must be taken under consideration as well.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #5 of 7 Old 12-06-2008, 04:08 PM Thread Starter
Famous337
The WJ has a wheelbase of 110 and its tow rating is like 5000? Im still confused.
Past:
2001 XJ 60th 265's
99 TJ. 32's
post #6 of 7 Old 12-06-2008, 04:30 PM
FPKites
ZJjazzyJim
FPKites's Avatar
The 4.0 WJ has a rating of 5,000
The 4.7 WJ has a rating of 6,500
http://www.wjjeeps.com/trailer.htm
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #7 of 7 Old 12-08-2008, 07:18 AM
onewhl750
1977 CJ7
Tow ratings are not just the engine. They include suspension, brakes, gear ratios, strength of components etc. If you put 1 ton running gear, under a 3/4 ton truck you are not legally able to tow at the 1 ton rating. Unfortunately the sticker on the door is the law, and no matter what you change, you cannot change the sticker without some pretty intensive work through the DOT.
1977 CJ7 4 inch suspension lift, 35 X 12.50 mud rovers.
2006 Dodge Ram 2500 Cummins, FASS 150, SMARTY, full set of gauges.
onewhl750 is offline
