94 f150 -- towing with an inline 300 - JeepForum.com
post #1 of 12 Old 04-03-2012, 09:09 PM Thread Starter
RaccoonJoe
I recently purchased a 94 f150 (long bed) for a tow rig and farm truck. It's 2wd, with the 300 inline 6 and a 5 sp. the plan was to use it to pull a 18' deck over tandem car trailer, with my 98 ZJ loaded for trail debauchery.
I pulled the ZJ about 200 interstate miles this weekend, on a tow dolly. The truck performed flawlessly, better than I had hoped for. However, the 300 seems to be lacking the horsepower to effectively deal with hills at 60 mph.
According to the dealer, my truck has a 3.07 rear gearset. With this in mind, my mod list has changed priority, from headers and possibly cam, to a rear with at least 3.73 gears.
Does this sound like a good idea? And can anyone help me to know what to look for in the local junkyards? (or, is my local dealer wrong again? 3.07 seems awfully tall for a 6 cyl, 5 sp 1/2 ton truck....)
Eagle Scout Jeep Club Member #4
Originally Posted by 4.0H.O.XJ
Ill have an XJ please, with a side order of 4.0, hold the catalyctic converter and the 02 sensors, thank you.
RaccoonJoe is offline
post #2 of 12 Old 04-04-2012, 07:47 AM
h2ogun
Ford 300 I6 have a lot of torque. Probably a good idea to go to the 3.73 gears. I think you will see an improvement. Assumptive that you are running the factory size tires. And depending on the size of the hills you may still find it lacking but still workable. I dont remember when that engine was changed to Fuel Injection, but if it only has a carb, you may want to consider FI to see both improvement and economy.
Good Luck.
h2ogun is offline
post #3 of 12 Old 04-04-2012, 09:19 AM
ajmorell
ajmorell's Avatar
94 was fuel injected
ajmorell is offline
post #4 of 12 Old 04-04-2012, 08:12 PM
wilson1010
I had that year and motor in an F250 and I am sure it was 4:11 or lower. Towed great.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #5 of 12 Old 04-04-2012, 09:01 PM
Millermagic
Very torquey engine - it will out tow a 302.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #6 of 12 Old 04-12-2012, 07:42 PM
jose_p_adams
I had a 94 f150 with a 302. It had 3.55 gears. There is a code on the inside of the drivers side door that denotes the gear ratio.
One other note about that truck is that the manual transmission that went into them was rated at 3,500 lbs towing while the automatic was rated at 7,000 lbs.
I towed my jeep with my truck once and the truck did not handle it well.
jose_p_adams is online now
post #7 of 12 Old 04-14-2012, 11:15 PM
Hashbrown
Blissfully Unaware
Hashbrown's Avatar
1980 CJ7
The 300 will pull about anything just won't pull it fast.
Live Free And Don't Be A Dick
Hashbrown is offline
post #8 of 12 Old 08-12-2012, 06:41 PM
tylermeyette
1988 XJ Cherokee
3.07 sound right I had a 1992 f150 300i6 with the Mazda 5 speed. 4x4. And it towed great. I pulled a 26 ft gooseneck with two Willys flat fenders better then the guy who owned the jeeps and trailers 1992 f150 with a 351 and an auto could. By far. He had 3.55 gears. Both of us had airbags. I had 234xxx miles on it. Never should have let it go. Best truck I've ever owned!
tylermeyette is offline
post #9 of 12 Old 08-13-2012, 10:03 AM
Mishimoto
Vendor
Mishimoto's Avatar
I've had a bunch of F150's, and they were all almost 3.55's. I'm guessing it's got the regular suspension and not the heavy duty package?
Mishimoto is offline
post #10 of 12 Old 08-13-2012, 03:05 PM
wilson1010
Same here. Year, motor and diff and it was a great tow rig.
My suggestion to the OP, just keep it in 4th gear on the highway. You will end up in about the same place as re-gearinng.
post #11 of 12 Old 04-21-2016, 11:39 PM
FarmerJohnson93
When towing and the engine bogs, like when you are going up a hill, down shift so you get more power and torque out of it, my 93 I6 5 spd pulled 9,000lbs of round bales on my bumper up and down hills like nothing and i wasnt pulling in overdrive (5th gear) i pull in 4th for more power.
FarmerJohnson93 is offline
post #12 of 12 Old 04-24-2016, 11:58 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
3.07's are too tall.
While you can keep it in 4th while pulling, a gear swap will accomplish more.
It will close the shift gaps up. This will allow you to keep the RPM's up on the upshift, which will help keep the engine in the sweet spot.
It will lower your first gear, greatly aiding in take off.
It will take some strain off the drivetrain, especially in the lower gears under acceleration.
3.50's would be a good choice and you should be able to find a solid used axle in a u pick yard for under 200 bucks. The beauty is if you don't like it, you can swap the stock axle back in a couple of hours.
My daughter has a 91 Bronco with the 300 in it and it doesn't have the spunk I would like either. While we know it is probably close to the 300k mark, it still doesn't burn oil or do anything bad. Since there is no cruise or other computer operated accessories, we have been floating the idea of converting to a small 4BBL.
bazinga
jeepdaddy2000 is offline
