5th wheel camper and short box truck? - JeepForum.com
post #1 of 6 Old 04-04-2012, 09:19 PM Thread Starter
Photog2000
Does anyone tow a 5th wheel camper with an extended cab short box. I could swear I have seen tons of people doing this but the local welding shop says there isnt enough room.
Photog2000 is offline
post #2 of 6 Old 04-04-2012, 09:22 PM
WindsorRenegade
What truck are we talking about?
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
post #3 of 6 Old 04-04-2012, 09:26 PM Thread Starter
Photog2000
98 F-250. This is the body style like the 97-03 F-150, not the superduty body style.
post #4 of 6 Old 04-04-2012, 11:15 PM
WindsorRenegade
Should be fine, I would think. I found this http://www.pullrite.com/superglide.htm on an F-150 site.
I think your 5th wheel needs a slider to be able to clear the cab on turns. So if you don't have that type of 5th wheel, then your welding shop is probably right.
post #5 of 6 Old 04-05-2012, 03:48 AM
hdsport
2008 WK
Can do !!!
Had a GMC 2500 Sierra Crew Cab with a short bed (6 1/2 ft, I believe) and pulled a 31 ft fifth wheel for several years.
I had a Reese 16K hitch w/ slider installed but NEVER had to use the slider.
The fifth wheel always cleared the cab in tight turns.
BUT, some fifth wheel units have a greater front overhang, so do some measuring to be sure.
Bought a motorhome...much nicer.
2001 Winnebago Adventurer 32v Motor Home
2008 Jeep GC Limited Toad, 4.7 L V-8, QTII
US Army Vet, 8th Army, 11th Evac SMBL Hospital, Pusan, South Korea
In God We Trust
hdsport is offline
post #6 of 6 Old 04-05-2012, 08:01 AM
USMCredneck
1979 CJ5
It can definitely be done, but you should be careful the first couple times you do it. The clearance you have will depend on the pin box and the front cap design on the trailer and also on the terrain you are on and placement of the hitch in the bed of the truck. The generally accepted location is, IIRC, about 6" ahead of the rear axle. Although you can place it directly over the rear axle to gain clearance, you then sacrifice weight distribution.
I towed my 30' 5th wheel with the short bed dodge I used to have. I measured the clearance I would have and it was a close fit. Instead of getting a slider hitch I bought a sidewinder pin box instead, although both would solve clearance issues.
79 CJ5. 258, T-18A, D20. 33s
08 Dodge Ram 3500 DRW DD/tow rig
USMCredneck is offline
truck camper question oteps Outdoor Recreation 3 04-18-2011 10:31 AM
Truck Camper TedderX_ General Discussion 0 06-22-2010 05:47 PM
Extended hitch for towing with a truck camper Lud04X Trailers & Towing 6 03-29-2009 02:55 PM
Is this truck short or long bed? POLBOSS General Discussion 11 01-20-2008 06:30 PM
Looking for a decent truck camper? Lud04X Outdoor Recreation 1 10-11-2007 06:25 AM
