$49.99 New Adjustable Tow Bar,HF - JeepForum.com
post #1 of 5 Old 02-08-2007, 11:46 PM Thread Starter
blueknight44
Just bought from Harbor Freight for $49.99 a Haul-Master adjustable tow bar model 94696.
5,000 lb capacity, 2" hitch coupler.
Safety chains aren't included.
4 wheel parts wanted $179.00 U-haul wanted $149.99
For technical questions or parts replacement call 1-800-444-3353
4 wheel parts has 10,000 lbs rated black tow hooks that have 2 pre drill holes that lineup to my 99 TJ front bumper mount bolts, cost was $4.99 each,
A 2"10,000 lb black tow hook that slides into a 2" receiver for $10.99 U-Haul gets $24.99
3/4 " shackle anchor for $13.99 this fits into my 2" hitch with the 2" ball removed.
blueknight44 is offline
post #2 of 5 Old 10-02-2012, 05:29 PM
MDS02
I have a 2004 Rubicon, and am wanting to tow behind a motor home. The jeep has 37" Good Year Wrangler tires. My concern with towing it is how well it will track behind the motor home and respond to curves and turning?
MDS02 is offline
post #3 of 5 Old 01-27-2013, 10:54 AM
boatsandhose
Yeah should follow you right along since it's so short.
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #4 of 5 Old 01-27-2013, 06:33 PM
PhulesAu
Should be fine, just won't back worth a Damn.
PhulesAu is offline
post #5 of 5 Old 01-27-2013, 06:40 PM
wolfcreek
With those tires and 4" suspension lift your caster may be off and it could reduce towing stability - how is your return to center now? ... you will have to give it a try - not a big investment.
I had (still have) the same tow bar setup and towed my 04 Rubicon over the cascades a few times when I still have 33" tires. I had experienced death wobble and lived in fear that it would happen while towing. Also did not relish the panic stop with the un-braked tow even though I was towing with a dually. Eventually I got a trailer, but I keep the tow bar as a back up.
wolfcreek is offline
Adjustable Dumbbells happymudder10 General Discussion 2 02-12-2010 08:12 AM
Thinking about an adjustable lift the88thpianoman General Discussion 6 10-18-2009 08:30 AM
Using an adjustable tow bar. DeepSky General Discussion 1 02-21-2009 11:43 PM
