A 416 for the TJ - JeepForum.com
post #1 of 6 Old 10-03-2013, 07:18 PM Thread Starter
JPNCA
A 416 for the TJ
There are some cool trailers here so I thought I might share mine
I grew up camping out of a Bantom trailer so I always wanted one.
As it happened I found what I believe to be a 416 on a ranch and talked the guy into parting with it.
It was in pieces and needed help
My main goal is to set it up to tow behind our TJ on camping trips
I had a friend make a new longer tongue
I swapped out the axle for one with 5 on 4.5 lugs to match the TJ
I wanted to keep it a spring under so I spaced the fenders with all- thread and washers
Other additions is an ammo box on the tongue, a vice mounted to it, a TJ rear tire carrier and a rattle can paint job
I'm sorry it's not the best write up and like all projects it will never be finished finished
Thanks to all for the help and ideas
JPNCA is offline
post #2 of 6 Old 10-08-2013, 09:57 AM
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
Lokks like a pretty solid build... I know you would sacrifes space in the trailer but you might consider relocating the spare up front... add some tongue weight too
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion, SOLD!) 89' Int. Harvester Toter (SOLD)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process/million pieces) 2000Kenworth Hauler
j_bydesign is offline
post #3 of 6 Old 10-08-2013, 08:05 PM Thread Starter
JPNCA
It actually tows perfect empty
Thinking about putting a water tank up front
http://store.adventuretrailers.com/p...ater-Tank.html
JPNCA is offline
post #4 of 6 Old 10-16-2013, 09:40 PM
jlp437
How stiff is the suspension with 2" of leaf springs!
looks great awesome work
jlp437 is offline
post #5 of 6 Old 10-16-2013, 11:02 PM Thread Starter
JPNCA
Thanks
Not too bad. I don't even run shocks
Holds a load pretty good too
Did bend a fender when my daughter failed to stay on the road
JPNCA is offline
post #6 of 6 Old 10-16-2013, 11:05 PM Thread Starter
JPNCA
Forgot to mention the table
JPNCA is offline
