-   Trailers & Towing (http://www.jeepforum.com/forum/f104/)
-   -   A 416 for the TJ (http://www.jeepforum.com/forum/f104/416-tj-1648505/)
JPNCA 10-03-2013 07:18 PM
A 416 for the TJ
There are some cool trailers here so I thought I might share mine :cheers2:
I grew up camping out of a Bantom trailer so I always wanted one.
As it happened I found what I believe to be a 416 on a ranch and talked the guy into parting with it.
It was in pieces and needed help
http://i264.photobucket.com/albums/i...r/DSCN2128.jpg
My main goal is to set it up to tow behind our TJ on camping trips
I had a friend make a new longer tongue
http://i264.photobucket.com/albums/i...railer/137.jpg
http://i264.photobucket.com/albums/i...railer/149.jpg
I swapped out the axle for one with 5 on 4.5 lugs to match the TJ
I wanted to keep it a spring under so I spaced the fenders with all- thread and washers
http://i264.photobucket.com/albums/i...r/f54fe010.jpg
http://i264.photobucket.com/albums/i...r/24b4ada1.jpg
http://i264.photobucket.com/albums/i...r/4eeab2ca.jpg
http://i264.photobucket.com/albums/i...r/3ef8a6bd.jpg
Other additions is an ammo box on the tongue, a vice mounted to it, a TJ rear tire carrier and a rattle can paint job
http://i264.photobucket.com/albums/i...02B37FB149.jpg
http://i264.photobucket.com/albums/i...02D5B69C23.jpg
http://i264.photobucket.com/albums/i...02CCBB1137.jpg
I'm sorry it's not the best write up and like all projects it will never be finished finished
Thanks to all for the help and ideas
j_bydesign 10-08-2013 09:57 AM
Lokks like a pretty solid build... I know you would sacrifes space in the trailer but you might consider relocating the spare up front... add some tongue weight too
JPNCA 10-08-2013 08:05 PM
It actually tows perfect empty
Thinking about putting a water tank up front
http://store.adventuretrailers.com/p...ater-Tank.html
jlp437 10-16-2013 09:40 PM
How stiff is the suspension with 2" of leaf springs!
looks great awesome work
JPNCA 10-16-2013 11:02 PM
Thanks
Not too bad. I don't even run shocks
Holds a load pretty good too
http://i264.photobucket.com/albums/i...74fdcc1ca5.jpg
Did bend a fender when my daughter failed to stay on the road
http://i264.photobucket.com/albums/i...6a0e174e8d.jpg
JPNCA 10-16-2013 11:05 PM
Forgot to mention the table
http://i264.photobucket.com/albums/i...538CD9446B.jpg
http://i264.photobucket.com/albums/i...5392394227.jpg
The time now is 02:27 AM.
