1950's Sears Trailer build - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > 1950's Sears Trailer build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-08-2012, 10:10 PM   #1
conceitedjake
I have been searching for years for a trailer suitable for dragging behind my Jeep when we go camping. I finally found one that I didn't have to finance to afford and started building.
The day I got it--
Refinishing the wheels-
After a ton of grinding/painting-
conceitedjake is offline   Reply With Quote Quick reply to this message
Unread 06-08-2012, 10:11 PM   #2
conceitedjake
One of the tires was unserviceable so I ordered a new firestone retro tire. Love those grave diggers-
Unread 06-08-2012, 10:13 PM   #3
conceitedjake
The first outing-
The trailer did awesome, tracked straight with no sway at all and very little bounce but that can be attributed to its really light weight.
Setting up camp-
I have square "jeep style" fenders on order too.
Unread 06-08-2012, 10:16 PM   #4
conceitedjake
Eventually I want to switch to a 3 axis coupler for offroading as soon as I can afford one without refinancing my house so I picked up a section of receiver tube to convert the tongue to accept a removable coupler.
Unread 06-10-2012, 12:30 AM   #5
conceitedjake
Does anyone have any tips/mistakes learned? Bueller? Bueller?
Unread 06-10-2012, 01:14 AM   #6
99_TJ_Wyoming
I recently saw a post of an off-road trailer with a u-joint between the tubes, I dont know if the pressure on a u-joint being 90 deg from designed would be a huge issue, they are made to withstand a lot of torque, so front to rear pressure shouldnt be that much greater than lateral pressure, I would say use the largest u-joint you can find, go to a salvage yard and see if you can get a truck drive shaft and cut both sides of a center joint, near a carrier bearing, that will be the strongest serviceable point in a class 8 drive shaft
99_TJ_Wyoming is offline   Reply With Quote Quick reply to this message
Unread 06-10-2012, 10:32 AM   #7
conceitedjake
Never thought of using a u joint.
Unread 06-10-2012, 10:34 AM   #8
BriansCJ
1994 XJ Cherokee
Why not just get a pintle set up?
5 Speed XJ Build - Daily Driver & Weekend Wheeler
1978 CJ5 Resto, w/ heavy mods - Slow
BriansCJ is offline   Reply With Quote Quick reply to this message
Unread 06-10-2012, 06:54 PM   #9
conceitedjake
I hate pintles. I'm military and have driven with them alot and that dang "bang, bang, bang" gets old really quick.
Unread 06-11-2012, 02:32 AM   #10
99_TJ_Wyoming
I just had a thought, you cant use a U-Joint unless its on a rotating plate so the trailer can tilt side to side independant of the Jeep on unlevel ground.
Unread 06-11-2012, 08:56 AM   #11
conceitedjake
I had already thought of that. I was envisioning using a trailer axle spindle to give me a bearing surface and a threaded portion so it would be able to be disassembled for service.
Unread 06-11-2012, 11:52 AM   #12
99_TJ_Wyoming
like this?
this is from JP magazine
http://www.jpmagazine.com/eventcover.../photo_14.html
Unread 06-11-2012, 05:40 PM   #13
conceitedjake
Kind of, I was going to weld the spindle into a section of 2"X2" tubing to allow a receiver on the trailer side as well as the Jeep side.
Unread 06-14-2012, 09:42 AM   #14
unlblkrubi
Fenders going back on? Those looked as good as the tires.
Black 13 JKUR
White 13 JKUR
___________________________________________
unlblkrubi is offline   Reply With Quote Quick reply to this message
Unread 06-18-2012, 12:27 PM   #15
conceitedjake
No, the fenders will be replaced by "Jeep Style" square fenders. The original fenders were kinked in all the wrong places and the body shop told me they would never get them right if they tried to fix them.
