1950's Sears Trailer build - JeepForum.com
post #1 of 39 Old 06-08-2012, 09:10 PM Thread Starter
conceitedjake
I have been searching for years for a trailer suitable for dragging behind my Jeep when we go camping. I finally found one that I didn't have to finance to afford and started building.
The day I got it--
Refinishing the wheels-
After a ton of grinding/painting-
conceitedjake is offline
post #2 of 39 Old 06-08-2012, 09:11 PM Thread Starter
conceitedjake
One of the tires was unserviceable so I ordered a new firestone retro tire. Love those grave diggers-
post #3 of 39 Old 06-08-2012, 09:13 PM Thread Starter
conceitedjake
The first outing-
The trailer did awesome, tracked straight with no sway at all and very little bounce but that can be attributed to its really light weight.
Setting up camp-
I have square "jeep style" fenders on order too.
post #4 of 39 Old 06-08-2012, 09:16 PM Thread Starter
conceitedjake
Eventually I want to switch to a 3 axis coupler for offroading as soon as I can afford one without refinancing my house so I picked up a section of receiver tube to convert the tongue to accept a removable coupler.
post #5 of 39 Old 06-09-2012, 11:30 PM Thread Starter
conceitedjake
Does anyone have any tips/mistakes learned? Bueller? Bueller?
post #6 of 39 Old 06-10-2012, 12:14 AM
99_TJ_Wyoming
I recently saw a post of an off-road trailer with a u-joint between the tubes, I dont know if the pressure on a u-joint being 90 deg from designed would be a huge issue, they are made to withstand a lot of torque, so front to rear pressure shouldnt be that much greater than lateral pressure, I would say use the largest u-joint you can find, go to a salvage yard and see if you can get a truck drive shaft and cut both sides of a center joint, near a carrier bearing, that will be the strongest serviceable point in a class 8 drive shaft
99_TJ_Wyoming is offline
post #7 of 39 Old 06-10-2012, 09:32 AM Thread Starter
conceitedjake
Never thought of using a u joint.
post #8 of 39 Old 06-10-2012, 09:34 AM
BriansCJ
1994 XJ Cherokee
Why not just get a pintle set up?
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #9 of 39 Old 06-10-2012, 05:54 PM Thread Starter
conceitedjake
I hate pintles. I'm military and have driven with them alot and that dang "bang, bang, bang" gets old really quick.
post #10 of 39 Old 06-11-2012, 01:32 AM
99_TJ_Wyoming
I just had a thought, you cant use a U-Joint unless its on a rotating plate so the trailer can tilt side to side independant of the Jeep on unlevel ground.
post #11 of 39 Old 06-11-2012, 07:56 AM Thread Starter
conceitedjake
I had already thought of that. I was envisioning using a trailer axle spindle to give me a bearing surface and a threaded portion so it would be able to be disassembled for service.
post #12 of 39 Old 06-11-2012, 10:52 AM
99_TJ_Wyoming
like this?
this is from JP magazine
http://www.jpmagazine.com/eventcover.../photo_14.html
post #13 of 39 Old 06-11-2012, 04:40 PM Thread Starter
conceitedjake
Kind of, I was going to weld the spindle into a section of 2"X2" tubing to allow a receiver on the trailer side as well as the Jeep side.
post #14 of 39 Old 06-14-2012, 08:42 AM
unlblkrubi
Fenders going back on? Those looked as good as the tires.
Black 13 JKUR 10th Annivsary
White 13 JKUR
___________________________________________
unlblkrubi is offline
post #15 of 39 Old 06-18-2012, 11:27 AM Thread Starter
conceitedjake
No, the fenders will be replaced by "Jeep Style" square fenders. The original fenders were kinked in all the wrong places and the body shop told me they would never get them right if they tried to fix them.
Greg's M101 CDN2 1/4 Ton Build "The Resale Red Offroad Trailer Build" GregB_00XJ Trailers & Towing 55 07-15-2015 05:47 PM
TJ Trailer Build for my LJ Lawdodge Trailers & Towing 23 05-01-2013 06:19 AM
Utility trailer build dylantheheeler Trailers & Towing 17 09-28-2010 09:26 PM
My little trailer build leolufse Trailers & Towing 7 09-26-2010 08:27 PM
Take one - Trailer Build ArrizX General Discussion 4 07-08-2009 12:53 PM
